PIM273
PIM273
    PIMORONI
    STP16CPC26 LED 阵列 16x16 Opto Raspberry Pi 平台评估扩展板
PIM273 数据手册
      Unicorn HAT HD PIM273         We've stepped up our LED game! Unicorn HAT HD crams 256 RGB LEDs, in a 16x16 matrix, onto a single HAT. High-definition rainbow goodness! You can still use it for all of the same things as the regular Unicorn HAT, but with 4 times as many pixels it makes much more complex animations possible, including scrolling text, and even low resolution videos. The bundled ninja diffuser makes the pixels look extra-shiny by providing some subtle diffusion, blurring the lines between each pixel. Simply use four of the nuts to space the diffuser slightly away from the HAT, and the other four to secure it. Features         256 RGB LED pixels in a 16x16 matrix  Pixels driven by ARM STM32F and three STP16CPC26 LED drivers  Bundled ninja diffuser, plus nuts and bolts  Unicorn HAT HD pinout  https://pinout.xyz/pinout/unicorn_hat_hd#  Compatible with Raspberry Pi 3, 2, B+, A+, Zero, and Zero W  Python library  https://github.com/pimoroni/unicorn‐hat‐hd  Comes fully assembled  The ARM chip on Unicorn HAT HD does all of the heavy lifting, meaning that you can just bung data to it and it'll take care of the rest. It acts as the man-in-the-middle between your Pi and the three STP16CPC26 LED drivers that actually drive the LEDs. Software   Our Python library will have your Unicorn HAT HD pooping out high-definition rainbows in a jiffy. There's a stack of examples too, to show you how to create slick animations, simulate the Game of Life, a forest fire or a flickering candle, and even scroll text! Notes    Photo‐sensitivity warning: flashing, strobing, and patterns of lights may cause epileptic seizures.  Always take care and immediately stop using if you feel unwell (dizziness, nausea, affected  vision, eye twitching, disorientation).  Power: Unicorn HAT HD requires a >2A microUSB power supply for your Pi. We recommend the  official Raspberry Pi power supply.        https://shop.pimoroni.com/products/unicorn‐hat‐hd 6/27/2017
PIM273 价格&库存
很抱歉,暂时无法提供与“PIM273”相匹配的价格&库存,您可以联系我们找货
