PIM345
PIM345
    PIMORONI
    箱 丙烯酸 蓝色 手持式 X
PIM345 数据手册
        Pibow PiTFT+   Support and protect your PiTFT+ and Raspberry Pi with this stylish and unique case! Features  Compatible with Raspberry Pi 3 B+, 3, & 2, but not with the original model B or B+  Custom top layers provided for both the 2.8" 320x240 and the 3.5" 480x320 PiTFT+ variants  Protects your beloved Pi!  Leaves all primary ports accessible  Made from lightweight high-quality cast acrylic  Great for hacking and tinkering!  Made in Sheffield, UK Crafted out of eleven unique layers, each laser-cut from colourful high-quality cast acrylic and once stacked they securely contain a Raspberry Pi 3 B+, 3 or 2 while leaving the primary ports accessible. Weighing only 92 grams the case is lightweight and ideal for mounting to any surface. No tools are required for assembly or disassembly. Notes  If using with the 480x320 3.5" PiTFT+, you will need to remove the mounting holes from the side of the PiTFT board (they're designed to be broken off cleanly)  This product is the Pibow PiTFT+ only, Raspberry Pi and PiTFT+ are not included        https://shop.pimoroni.com/products/pibow‐pitft  5‐24‐18
PIM345 价格&库存
很抱歉,暂时无法提供与“PIM345”相匹配的价格&库存,您可以联系我们找货
PIM345
    • 1+173.094001+22.39236
    库存:4
