PIM355
PIM355
    PIMORONI
    BME280,TCS3472 湿度,光照,压力,声音,温度 传感器 micro:bit 平台评估扩展板
PIM355 数据手册
enviro:bit PIM355 Sense the world around you with enviro:bit! It's loaded with sensors for air and weather, colour and light, and sound, and slots right onto your micro:bit. Just slot in your micro:bit, then code enviro:bit with the block-based Microsoft MakeCode editor, or with MicroPython in the Mu code editor. The sensors go hand-inhand really well with the LED matrix on micro:bit, letting you graph sensors readings or have the LEDs react to sound, for example. Features • Comes fully-assembled and ready to use • BME280 temperature, pressure, and humidity sensor • TCS3472 light and colour sensor • MEMS microphone • Compatible with micro:bit • Microsoft MakeCode and MicroPython support • No soldering required! Software You can code enviro:bit with the block-based Microsoft MakeCode editor, that'll get you started with using the sensor readings from enviro:bit, if you want to delve deeper, then you can use MicroPython in the Mu code editor. To add the enviro:bit library in MakeCode, click on the cog at the top right hand corner, then "Add Package", then search for "envirobit". You can find full instructions at the GitHub repository for the library. Our MicroPython library for enviro:bit is also available at GitHub, again with full instructions on how to get going with it. https://shop.pimoroni.com/products/enviro-bit 6-11-18
PIM355 价格&库存
很抱歉,暂时无法提供与“PIM355”相匹配的价格&库存,您可以联系我们找货
