PIM356
PIM356
    PIMORONI
    NOISE:BIT
PIM356 数据手册
noise:bit PIM356 Make your micro:bit sing with noise:bit! It's a tiny speaker that packs a fair bit of punch, and it's perfect for BLEEPS and BLOOPS! Just slot in your micro:bit, and use the sound generation blocks and code in Microsoft MakeCode and MicroPython to generate tones, sounds, and speech. We've had great fun combining it with enviro:bit's light sensor to make a radio-controlled theremin! Features • Comes fully-assembled and ready to use • TPA301 amplifier chip • 8Ω 2W Mylar speaker • Compatible with micro:bit • No soldering required! Software You can code noise:bit with the block-based Microsoft MakeCode editor, using its audio generation blocks, if you want to delve deeper, then you can use MicroPython in the Mu code editor. https://shop.pimoroni.com/products/led-shim#description 6-11-18
PIM356 价格&库存
很抱歉,暂时无法提供与“PIM356”相匹配的价格&库存,您可以联系我们找货
