PIM371
PIM371
    PIMORONI
    自动化 接口 micro:bit 平台评估扩展板
PIM371 数据手册
        automation:bit PIM371 Control and monitor your world with automation:bit! It's tolerant of up to 24V, with analog and digital inputs, outputs, and a relay, so it's ideal for automating low-voltage systems in your home. Just slot in your micro:bit, then code automation:bit with the block-based Microsoft MakeCode editor. Hook up buttons to the inputs, use the built-in buttons on micro:bit, or the light-sensing capability of the LED matrix to control devices connected to automation:bit. Or why not use a second micro:bit's radio function as a remote control? WARNING! automation:bit should not be used with voltages greater than 24V and especially not with mains voltages! Features  Comes fully-assembled and ready to use  1 x 24V @ 2A relay (NC and NO terminals)  3 x ADC channels (0-24V range)  3 x 24V tolerant buffered inputs  3 x 24V tolerant sinking outputs  3.5mm screw terminals  Compatible with micro:bit  Microsoft MakeCode support  No soldering required! Software You can code automation:bit with the block-based Microsoft MakeCode editor, that'll get you started with using all of automation:bit's functionality. To add the automation:bit library in MakeCode, click on the cog at the top right hand corner, then "Add Package", then enter the URL "https://github.com/pimoroni/pxtautomationbit". You can find full instructions at the GitHub repository for the library.                                       https://shop.pimoroni.com/products/automation‐bit#description 8‐20‐18
PIM371 价格&库存
很抱歉,暂时无法提供与“PIM371”相匹配的价格&库存,您可以联系我们找货
PIM371
  • 9+174.265779+22.58816
