HDMI 8" IPS LCD Screen Kit
(1024x768) PIM372
A high-resolution 8", IPS, 1024x768, HDMI display, with
Pimoroni-made display driver board and keypad, that's perfect
for building into projects like arcade cabinets, or just use it as
a handy display for your Raspberry Pi!
This new 8" display is a step up from our previous one, with a higher-resolution
1024x768 IPS screen, and a display driver board and keypad designed and made by
Pimoroni. It's the same, good old 4:3 aspect ratio, making it ideal for retro gaming
builds.
There's even a little keypad (and cable) included to control the display and navigate the
menu options, and we've broken those pins out on the board too, so you can use your
own buttons if you like.
Just supply the display driver board with 5V and at least 780mA through a micro-USB
cable or power supply and you're good to go!
Display features
1024x768 resolution
IPS, wide-viewing angle display (170°)
60Hz refresh rate (12.5ms average response time)
Contrast ratio: 500:1 (white:black)
Brightness: 350 cd/m2 (nits)
Outer dimensions: 174x136x3mm
Screen area: 165x124mm
Weight: 125g
Display driver board features
Pimoroni-made display driver board (HDMI>LVDS)
Keypad and controllable backlight brightness, contrast, and saturation
HDMI input
Power supply: 5V, 780mA
Driver board dimensions: 65x56.5x8.5mm
Keypad dimensions: 56x13.5x4.25mm
Keypad ribbon cable length: 20cm
https://shop.pimoroni.com/products/automation‐bit#description 8‐20‐18
很抱歉,暂时无法提供与“PIM372”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2+1127.863402+146.56873
