6-button kit – Picade Plasma Kit Illuminated Arcade Buttons
PIM417
Add technicolour brilliance to your Picade or Picade Console
with this addressable RGB LED arcade button kit, available in
a 6-button kit (console buttons) or 10-button kit (all buttons).
Swap out your Picade's arcade buttons for the crystal clear ones in this kit, pop one of
the Picade Plasma PCBs over the button's spade terminals, hold the PCB in place with
the spade connectors, and chain all of the Plasma PCBs together with the included
cables. Use the host cable to connect the Plasma chain to your Picade X HAT, install
our Picade Plasma software, and BAM, your Picade is 110% more colourful!
Each Picade Plasma PCB has four tiny, addressable, RGB LEDs (APA102) and a data
in and data out JST connector. They're designed to fit neatly inside the recess on the
back of our low-profile arcade buttons and shine their light through the clear plastic. The
white PCB bounces an spilled light from the LEDs to give them extra GLOW.
Six-Button Kit Contents
6x clear 30mm push-fit arcade buttons
6x Picade Plasma PCBs
5x 10cm button cables
1x 30cm host cable
Ten-Button Kit Contents
10x clear 30mm push-fit arcade buttons
10x Picade Plasma PCBs
4x 30cm buttons cables
1x 30cm host cable
Picade Plasma Features
APA102 addressable RGB LEDs
Chain-able
JST connectors for data in and data out
Designed for our low-profile arcade buttons
Connects to the Hack Header on our Picade X HAT
Python daemon
As well as using Plasma buttons with Picade and Picade X HAT, you can connect them
straight to GPIO on your Pi, or other microcontroller. This makes them ideal for DIY
arcade builds and even building things like your own DIY midi controller.
You can read our tutorial on fitting Picade Plasma buttons to find out how to fit the
buttons and control them with the Picade Plasma software.
Notes
PCB dimensions: 24mm diameter, 5.75mm thick (including JST connector)
LED brightness is limited to a sensible level in software. Adjust this at your peril!
Picade Console is for illustration only, and not included!
https://shop.pimoroni.com/products/picade‐plasma‐kit‐illuminated‐arcade‐buttons?variant=15403722670163/12‐7‐18
很抱歉,暂时无法提供与“PIM417”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4+426.449054+55.41815
