PIM428
PIM428
    PIMORONI
    COUPE TANGERINE PIBOW 3 A+ COU
PIM428 数据手册
        Coupé Tangerine – Pibow 3 A+ Coupé (for Raspberry Pi 3 A+)  PIM428 Pibow 3 A+ Coupé. The slim, hackable, and attractive case for the Raspberry Pi 3 A+, now in four colour options including RAINBOW! Features  Compatible with Raspberry Pi 3 A+  Extra venting top and bottom, and a place for installing a heatsink if you really want to push your Pi  Super-slimline profile  Fully HAT-compatible  Works great with standoffs!  Protects your beloved Pi!  Clear top leaves Raspberry Pi 3 A+ visible  GPIO cut-out with laser-etched pin labels  Leaves all ports accessible  Made from lightweight, high-quality, cast acrylic  Great for hacking and tinkering!  Made in Sheffield, UK Crafted out of five unique layers including a transparent top and base that leave your beautiful Pi visible inside. Each layer is laser-cut from colourful, high-quality, cast acrylic and once stacked they securely contain your Raspberry Pi 3 A+, while leaving the primary ports, including the camera port, display port, and GPIO accessible. Weighing a shade under 50 grams, the case is lightweight and ideal for mounting to any surface. No tools are required for assembly or disassembly. The dimensions are: 79x66x15mm (WxLxH, not including bolt heads and nuts)                                https://shop.pimoroni.com/products/pibow‐3‐a‐plus‐coupe?variant=17988387930195/12‐7‐18
PIM428 价格&库存
很抱歉,暂时无法提供与“PIM428”相匹配的价格&库存,您可以联系我们找货
