5x5 RGB Matrix Breakout
PIM435
This super-cute 5x5 RGB LED matrix breakout is a neat way
to visualise sensor data or for simple animations or
notifications, and it's Raspberry Pi and Arduino-compatible.
These little matrices are ideal for visualising data from other Pimoroni breakouts in
a Breakout Garden HAT, like graphing environmental data from
our BMP280 or BME680 breakouts. Or why not use two together as headlights or brake
lights for your Pi-powered vehicle?
Like our other breakouts, this one just pops straight onto your Pi's pins once you've
soldered on the included right-angle female header, and we included a trace that can be
cut to change the I2C address from 0x74 to 0x77, if you want to use two matrices at
once!
It's compatible with our fancy Breakout Garden HAT, where using breakouts is as easy
just popping it into one of the six slots and starting to grow your project, create, and
code.
Features
5x5 (25 total) RGB LEDs
Uses the IS31FL3731 driver chip
15x15mm active area
3.5mm LED pitch
I2C interface (address 0x74/0x77 (cut trace))
3.3V or 5V compatible
Reverse polarity protection
Compatible with all models of Raspberry Pi, and Arduino
Python library
Kit includes
1x5 male header
1x5 female right-angle header
We've designed this breakout board so that you can solder on the piece of right-angle
female header and pop it straight onto the bottom left 5 pins on your Raspberry Pi's
GPIO header (pins 1, 3, 5, 7, 9).
Software
We've put together a Python library to make it really easy to drive the 5x5 RGB Matrix
Breakout, along with a handful of examples to show what it can do.
Our software does not support Raspbian Wheezy.
Notes
Dimensions: 19x29x3.5mm.
https://shop.pimoroni.com/products/5x5‐rgb‐matrix‐breakout/3‐19‐19
很抱歉,暂时无法提供与“PIM435”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+98.167301+12.50290
