0.96" SPI Colour LCD (160x80)
Breakout PIM436
A handy lil' LCD to add readouts to your projects. This 0.96"
SPI LCD has a 2:1 widescreen aspect ratio, has great viewing
angles (IPS), and works with Raspberry Pi or Arduino.
The display is great for displaying tidbits of information like timers, clocks,
sensor readings, and more. Why not use it to display the IP address of a headless
Raspberry Pi, so that you don't have to connect a full display or fiddle around with
nmap?
Despite being so diminutive, this LCD is a gorgeous little display. It's bright, has great
resolution and, because it's an IPS panel, it has wide viewing angles and looks
great whichever way you look at it. It's driven by SPI and you should be able to run it at
up to ~50FPS, although we've found that anywhere from 10FPS looks good for most
uses.
Note that this breakout is not compatible with our current Breakout Garden(more
news on that front soon!), since it uses SPI rather than I2C, and has 7 pins rather than 5
like most of our other breakouts.
Features
0.96" colour LCD (160x80 pixels)
SPI interface
3.3V or 5V compatible
Reverse polarity protection
Requires soldering
Compatible with all models of Raspberry Pi and Arduino
Python library
Display specifications
160x80 pixels (~190 PPI)
10.8x21.7mm active area
400cd/m2 luminance
800:1 contrast ratio
160° viewing angle (horizontal and vertical)
ST7735S driver chip
Software
We've adapted an existing Python library to drive this display. The library makes it
straightforward to display images, text or graphics, and even display animated GIFs!
There's a one-line-installer to get the library all set up for you. Just open a terminal and
type: curl https://get.pimoroni.com/st7735 | bash
Connecting to your Raspberry Pi
Our library is set up to use SPI 0 on the Pi (BCM 8 for CS, BCM 11 for SCK, and BCM
10 for MOSI), BCM 9 for DC, and BCM 18 for the backlight.
Here's which pins to connect between your 0.96" LCD Breakout and your Pi's GPIO
(note that it's BCM pin numbering):
3-5V to any 5V or 3V pin
CS to BCM 8
SCK to BCM 11
MOSI to BCM 10
DC to BCM 9
BL to BCM 18
GND to any ground pin
You can of course use other pins with your LCD Breakout, but you'll have to change
them accordingly when you instantiate the display in your code.
Notes
Dimensions: 29.1x25.9x5.4mm
https://shop.pimoroni.com/products/0‐96‐spi‐colour‐lcd‐160x80‐breakout/3‐19‐19
很抱歉,暂时无法提供与“PIM436”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+192.373441+24.99942
