PIM444
PIM444
    PIMORONI
    弓形板 接口 评估板
PIM444 数据手册
        Player X USB Games Controller PCB PIM444 Player X has entered the game! Add some arcade buttons (up to twelve) and a joystick and you've got your own homebrew USB games controller. BAZINGA! This tiny PCB connects to your PC, Mac, or Linux machine with a standard USB microB cable, and appears as a USB games controller. Then it's just a matter of adding some arcade buttons and a joystick (our Arcade Parts Kit has everything you need, except the USB cable) as input. The buttons and joystick plug into Player X with male DuPont connectors (jumper jerky), which you'll find on one end of our wiring loom. There's also a connector for our Plasma Buttons if you want to add some rainbow-illuminated button-bashing to your games controller. Player X PCBs are also stackable, using M2.5 standoffs, so you can use it to build two, three-, or even four-player controllers! Features         USB games controller No-solder DuPont connectors for joystick and buttons 1x joystick and up to 12x arcade buttons Tactile shutdown button Plasma button connector Connects via USB micro-B cable Mounting holes (M2.5, 58mm apart) Dimensions: 65x20x7.5mm         https://shop.pimoroni.com/products/player‐x‐usb‐games‐controller‐pcb/8‐5‐19
PIM444 价格&库存
很抱歉,暂时无法提供与“PIM444”相匹配的价格&库存,您可以联系我们找货
PIM444
    • 11+127.2624811+16.53809
