PIM452
PIM452
    PIMORONI
    DRV2605L 触觉/振动电机 电机/触觉 平台评估扩展板
PIM452 数据手册
  DRV2605L Linear Actuator Haptic Breakout PIM452 This DRV2605L haptic driver breakout with linear actuator will really get you buzzing! The powerful haptic buzz is programmable with a range of built-in patterns, or you can program your own. This little haptic driver and actuator is great for adding some buzzy feedback to your projects. We combined it with our Trackball Breakout to give some old-school haptic feedback to scroll and clicks (click here to see the example code). It's compatible with our fancy Breakout Garden HAT (and pHAT), where using breakouts is as easy just popping it into one of the six slots and starting to grow your project, create, and code. Features  DRV2605L haptic driver chip (datasheet)  ELV1411A linear resonant actuator  I2C interface (address 0x5A)  3.3V or 5V compatible  Reverse polarity protection  Compatible with all models of Raspberry Pi, and Arduino  Python library Kit includes  DRV2605L linear actuator haptic breakout  1x5 male header  1x5 female right-angle header We've designed this breakout board so that you can solder on the piece of right angle female header and pop it straight onto the bottom left 5 pins on your Raspberry Pi's GPIO header (pins 1, 3, 5, 6, 9). Software We've put together a Python library that you can use to make your DRV2605L Linear Actuator Haptic Breakout buzzzzzzz and an easy one-line installer to install everything. Our software does not support Raspbian Wheezy. Notes Dimensions: 19x23.5x5.25mm https://shop.pimoroni.com/products/drv2605l‐linear‐actuator‐haptic‐breakout/6‐13‐19
PIM452 价格&库存
很抱歉,暂时无法提供与“PIM452”相匹配的价格&库存,您可以联系我们找货
