PIM457
PIM457
    PIMORONI
    分接板 连接性 micro:bit 平台评估扩展板
PIM457 数据手册
        Pinbetween  PIM457 Pinbetween gives you access to all of the micro:bit's pins at the same time as using an edge-connector add-on, and it's completely solderless! The 40-pin male header on Pinbetween lets you use jumper jerky to connect extra bits to your micro:bit while using an edge-connector add-on like our enviro:bit, for example. Plug your micro:bit into the edge-connector at the top, attach your micro:bit add-on at the bottom, and then use the handily grouped and labelled pins in-between for whatever you wish! Note: micro:bit, enviro:bit, breadboard, etc. pictured are not included! Features  Comes fully-assembled and ready to use  40-pin male header for use with jumper jerky  Grouped and labelled pins  Plenty of power pins (9x 3V, 12x ground)  Male edge connector for micro:bit add-ons  Compatible with micro:bit  No soldering required!  Dimensions: 56x41.5x12mm       https://shop.pimoroni.com/products/pinbetween#description/6‐13‐19
PIM457 价格&库存
很抱歉,暂时无法提供与“PIM457”相匹配的价格&库存,您可以联系我们找货
