Pibow Coupé 4
PIM465 Pibow Coupé 4 – Rainbow
PIM464 Pibow Coupé 4 – Red
PIM463 Pibow Coupé 4 – Ninja
The slim, hackable, and attractive case for the Raspberry
Pi 4! Now also available in rainbow!
Note: This Pibow Coupé is only compatible with the Raspberry Pi 4! If you want a
Pibow Coupé for a Raspberry Pi 3 B+ or earlier then you should get this one!
Features
Compatible with Raspberry Pi 4 only
Cutout in lid for 40x30mm heatsink or Fan SHIM
Super-slimline profile
Fully HAT-compatible
Works great with standoffs!
Protects your beloved Pi!
Clear top and base (Ninja and Red) leave Raspberry Pi 4 visible
GPIO cut-out
Handy laser-etched port labels
Leaves all ports accessible
Made from lightweight, high-quality, cast acrylic
Great for hacking and tinkering!
Made in Sheffield, UK
Crafted out of five unique layers including a transparent top and base (Red and Ninja)
that leave your beautiful Raspberry Pi 4 visible inside. Each layer is laser-cut from
colourful, high-quality, cast acrylic and once stacked they securely contain a Raspberry
Pi 4 while leaving the primary ports, including the camera port, display port, and GPIO
accessible.
Weighing just over 50 grams, the case is lightweight and ideal for mounting to any
surface. No tools are required for assembly or disassembly. The dimensions are:
99x66x15mm (WxLxH, not including bolt heads and nuts).
Assembly
Here's a lovely little video from Tanya on how to assemble your Pibow Coupé 4
case. Don't forget to peel the white protective film off the layers!
https://shop.pimoroni.com/products/pibow-coupe-4/7-18-19
很抱歉,暂时无法提供与“PIM465”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+109.671841+14.25214
