PIM463
PIM463
    PIMORONI
    箱 丙烯酸 黑色 手持式 2.598" 长 x 3.898" 宽(66.00mm x 99.00mm) X 0.591"(15.00mm)
PIM463 数据手册
Pibow Coupé 4 PIM465 Pibow Coupé 4 – Rainbow PIM464 Pibow Coupé 4 – Red PIM463 Pibow Coupé 4 – Ninja The slim, hackable, and attractive case for the Raspberry Pi 4! Now also available in rainbow! Note: This Pibow Coupé is only compatible with the Raspberry Pi 4! If you want a Pibow Coupé for a Raspberry Pi 3 B+ or earlier then you should get this one! Features              Compatible with Raspberry Pi 4 only Cutout in lid for 40x30mm heatsink or Fan SHIM Super-slimline profile Fully HAT-compatible Works great with standoffs! Protects your beloved Pi! Clear top and base (Ninja and Red) leave Raspberry Pi 4 visible GPIO cut-out Handy laser-etched port labels Leaves all ports accessible Made from lightweight, high-quality, cast acrylic Great for hacking and tinkering! Made in Sheffield, UK Crafted out of five unique layers including a transparent top and base (Red and Ninja) that leave your beautiful Raspberry Pi 4 visible inside. Each layer is laser-cut from colourful, high-quality, cast acrylic and once stacked they securely contain a Raspberry Pi 4 while leaving the primary ports, including the camera port, display port, and GPIO accessible. Weighing just over 50 grams, the case is lightweight and ideal for mounting to any surface. No tools are required for assembly or disassembly. The dimensions are: 99x66x15mm (WxLxH, not including bolt heads and nuts). Assembly Here's a lovely little video from Tanya on how to assemble your Pibow Coupé 4 case. Don't forget to peel the white protective film off the layers! \      PIM465 Pibow Coupé 4 – Rainbow     PIM463 Pibow Coupé 4 – Ninja   PIM464 Pibow Coupé 4 – Red https://shop.pimoroni.com/products/pibow-coupe-4/7-18-19
PIM463 价格&库存
很抱歉,暂时无法提供与“PIM463”相匹配的价格&库存,您可以联系我们找货
PIM463
  • 1+117.496401+15.26896
库存:6
