PIM471
PIM471
    PIMORONI
    游戏套件 元器件
PIM471 数据手册
  Arcade Parts Kit PIM471 This handy dandy Arcade Parts Kit has all the components you need to build your own DIY arcade machine: joystick, ten buttons, and wiring loom. Just add a Picade X HAT or Player X USB as the controller. Building your own arcade machine, or need to reboot an old arcade cabinet? This kit all the bits you need, except the brains! The joystick, buttons, and wiring loom work perfectly with both our Picade X HAT for Raspberry Pi, and Player X USB Games Controller PCB, so just pick whichever suits your needs best, and PEW PEW away you go... Kit contents    Clicky joystick with black ball top (with 5-pin connector) 10x 30mm push-fit arcade buttons (4x black, 2x yellow, 2x pink, 2x blue) Wiring loom Joystick specifications      35mm black ball top Black dust cover 8-way square restrictor gate 9mm diameter, 36mm tall shaft 5-pin connector  More information here This clicky joystick is great for DIY arcade builds, and it has a handy 5-pin connector that means connecting it is just a case of plugging in a single cable connector. We use this joystick in our new Picade and it's solid, responsive, and reliable. The feel is a little looser than the Zippyy joystick that we sell, more similar to a Japanese joystick. Pair it with a Raspberry Pi, Picade X HAT, and some arcade buttons and you've got all the controls you need to build your own arcade machine! We'd recommend also picking up one of our new Picade wiring looms, which includes a 5-pin connector to 5x Dupont connector cable that can be used with this joystick. Features       35mm black ball top  Black dust cover  8‐way square restrictor gate  9mm diameter, 36mm tall shaft   5‐pin connector (compatible with JST‐XH cable)  Notes       Pinout: up, down, right, left, ground (from pin closest to centre)  Overall dimensions (including ball‐top): 106x70x95mm  Mounting plate dimensions: 60x95mm  Corner hole centres (5mm holes): 44x82mm  Centre hole centres (6mm holes): 85mm  https://shop.pimoroni.com/products/arcade‐parts‐kit/8‐5‐19
PIM471 价格&库存
很抱歉,暂时无法提供与“PIM471”相匹配的价格&库存,您可以联系我们找货
PIM471
    • 5+272.103025+35.24219
