PIM476
PIM476
    PIMORONI
    ST7789V LCD 1.3" 显示 Pimoroni 分线板 平台评估扩展板
PIM476 数据手册
       1.3" SPI Colour LCD (240x240) Breakout PIM476 Crisp, high-res, with great viewing angles (IPS), this 1.3" square, 240x240 pixel, colour LCD will add some pizzazz to your Raspberry Pi or Arduino projects. The square form-factor of this display makes it great for cramming lots of information on—data, graphs, even things like album art and photos. Like our smaller 0.9" LCD breakout, this one is an IPS display, so it has great viewing angles and it's super-crisp and bright. It's driven by SPI and you should be able to run it at up to ~50FPS, although we've found that anywhere from 10FPS looks good for most uses. You can use this breakout completely solder-free with our Breakout Garden HAT with SPI! Features       1.3" colour LCD (240x240 pixels) SPI interface 3.3V or 5V compatible Reverse polarity protection Compatible with all models of Raspberry Pi and Arduino Python library Display specificatio       240x240 pixels (~260 PPI) 23.4x23.4mm active area 250m2 luminance 800:1 contrast ratio 160° viewing angle (horizontal and vertical) ST7789V driver chip Software We've adapted an existing Python library to drive this display. The library makes it straightforward to display images, text or graphics, and even display animated GIFs! Connecting to your Raspberry Pi If you're not using our Breakout Garden HAT with SPI, then this is how to connect your LCD Breakout up to your Raspberry Pi. Our library is set up to use SPI 0 on the Pi (BCM 8 for CS, BCM 11 for SCK, and BCM 10 for MOSI), BCM 9 for DC, and BCM 18 for the backlight. Here's which pins to connect between your 1.3" LCD Breakout and your Pi's GPIO (note that it's BCM pin numbering):       3-5V to any 5V or 3V pin CS to BCM 8 SCK to BCM 11 MOSI to BCM 10 DC to BCM 9 BL to BCM 18  GND to any ground pin You can of course use other pins with your LCD Breakout, but you'll have to change them accordingly when you instantiate the display in your code. Notes Dimensions: 41.2x26.6x5.5mm                   https://shop.pimoroni.com/products/1‐3‐spi‐colour‐lcd‐240x240‐breakout/10‐10‐19
PIM476 价格&库存
很抱歉,暂时无法提供与“PIM476”相匹配的价格&库存,您可以联系我们找货
