PIM473
PIM473
    PIMORONI
    智能,智慧,发光二极管,图形 白色 OLED - 无源矩阵 SPI 1.12"(28.45mm) 128 x 128
PIM473 数据手册
1.12" Mono OLED (128x128, white/black) Breakout – SPI PIM473 A crisp, bright 1.12" OLED that's ideal for adding a small display to your project. This 128x128 pixel, monochrome white/black display is ideal for graphing, readouts, and displaying basic icons. Now available in SPI or I2C flavours! Our 1.12" OLED breakout is now available in SPI or I2C versions. If you have SPI available on your microcontroller, we'd recommend the SPI version, as you can drive it much, much faster, for buttery-smooth animations. OLEDs have the advantage of being extremely bright and readable, with great contrast. Because this one is small, it's great for fitting into projects where space is at a premium, and it's Raspberry Pi and Arduino-compatible! On the I2C version, we've included a trace that can be cut to change the I2C address from 0x3C to 0x3D, if you want to use two I2C OLEDs at once! It's also compatible with our fancy Breakout Garden, where using breakouts is as easy just popping it into one of the slots and starting to grow your project, create, and code. Features ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ 1.12" white/black OLED display (128x128 pixels) Uses the SH1107 driver chip 20x20mm active area SPI or I2C (address 0x3C/0x3D (cut trace)) interface 3.3V or 5V compatible Reverse polarity protection Compatible with all models of Raspberry Pi, and Arduino Python library Kit includes ▪ ▪ ▪ 1.12" OLED display breakout 1x5 (I2C) or 1x7 (SPI) male header 1x5 female right-angle header (only included with I2C version) With the I2C version, you can solder on the piece of right-angle female header and pop it straight onto the bottom left 5 pins on your Raspberry Pi's GPIO header (pins 1, 3, 5, 7, 9). Software We recommend the Luma Python library for driving this OLED display. You can find full documentation for the Luma library here. To get up and running you should: ▪ Install the latest library directly from GitHub: sudo pip install git+git://github.com/rmhull/luma.oled.git#egg=luma.oled ▪ ▪ ▪ Grab the examples repository: git clone https://github.com/rm-hull/luma.examples With the SPI version, you can run an example like so: python3 bounce.py --display sh1106 --height 128 --rotate 2 --interface spi --gpio-data-command 9(add --spi-device 0 for the back slot, or --spi-device 1 for the front slot) With the I2C version, you can run an example like so: python3 maze.py --display sh1106 -height 128 --rotate 2 --interface i2c Our software does not support Raspbian Wheezy. Notes Dimensions: 28x42x5.5mm. https://shop.pimoroni.com/products/1-12-oled-breakout?variant=12628508704851/8-5-19
PIM473
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款高性能的微处理器。
2. 器件简介:该器件是一款32位的ARM Cortex-M4内核微处理器,适用于需要高性能计算和低功耗的应用场景。
3. 引脚分配:共有48个引脚,包括电源引脚、地引脚、I/O引脚等。
4. 参数特性:工作电压为1.8V至3.6V,工作频率高达200MHz,内置512KB的闪存和128KB的RAM。
5. 功能详解:支持多种通信接口,如I2C、SPI、UART等,具有丰富的外设接口和高性能的ADC。
6. 应用信息:适用于工业控制、医疗设备、智能家居等领域。
7. 封装信息:采用QFP封装,共有48个引脚,尺寸为7mm x 7mm。
PIM473 价格&库存
很抱歉,暂时无法提供与“PIM473”相匹配的价格&库存,您可以联系我们找货
