Particulate Matter Sensor Breakout (for
PMS5003)
PIM477
A handy-dandy breakout that converts between the
picoblade connector cable on the PMS5003 particulate
matter sensor and a standard male 2.54mm pitch header.
Use this breakout to connect a PMS5003 particulate matter sensor straight to your
Raspberry Pi (or other microcontroller) with some female-to-female jumper jerky,
using our PMS5003 Python library to read data from the sensor.
Connect the pins on the breakout to the following pins on your Raspberry Pi:
5V to 5V
GND to ground
TX to BCM 14
RX to BCM 15
RESET to BCM 27
EN to BCM 22
Dimensions: 17.7x17.75mm
https://shop.pimoroni.com/products/particulate‐matter‐sensor‐breakout/10‐10‐19
很抱歉,暂时无法提供与“PIM477”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+39.120951+5.07719
