PIM479
PIM479
    PIMORONI
    DRV8830 电机控制器/驱动器 电源管理 Pimoroni 分线板 平台评估扩展板
PIM479 数据手册
      DRV8830 DC Motor Driver Breakout PIM479 An H-bridge DC motor driver with configurable current limit (0.2 or 1A) and up to four different I2C addresses. Great for DIY robot builds. This little brushed DC motor driver is speed-controllable, bi-directional, and has a configurable current limit that can be increased to 1A (from 0.2A) by cutting a trace on the underside of the board. You can use up to four at once, and control them independently, by changing the I2C address (configurable by cutting one or both of the address traces). The DRV8830 breakout has an I2C interface and is 3.3V or 5V compatible. Like our other Pimoroni breakouts, we've designed it so that you can solder a piece of rightangle header onto it and then pop it straight onto the bottom left 5 pins on your Raspberry Pi's GPIO header (pins 1, 3, 5, 6, 9). It's also compatible with our fancy Breakout Garden, where using breakouts is as easy as just popping it into one of the six slots and starting to grow your project, create, and code. Features           DRV8830 motor driver (datasheet) Speed, direction, and braking control Bright white status LED Configurable current limit (0.2 or 1A) 3.3V or 5V compatible I2C interface (addresses 0x60, 0x61, 0x63, 0x64) Reverse polarity protection Raspberry Pi-compatible pinout (pins 1, 3, 5, 7, 9) Compatible with all models of Raspberry Pi, and Arduino Python library Kit includes    DRV8830 Breakout 1x5 male header 1x5 female right angle header Software We've put together a Python library that you can use to control your DRV8830 Breakout, with easy control over speed, direction, braking, and a bunch of other functions. Nice! Notes   The text saying "I2C: 0x60 to 0x68" on the underside of the board is incorrect. The address range is 0x60, 0x61, 0x63, and 0x64. Dimensions: 22x19x12mm     https://shop.pimoroni.com/products/drv8830‐dc‐motor‐driver‐breakout/10‐10‐19
PIM479
PDF文档中的物料型号为STM32F103RCT6,是一款基于ARM Cortex-M3内核的微控制器。
器件简介显示,它具有多种外设和通信接口,如GPIO、ADC、USART、SPI、I2C等,适用于多种应用场景。
引脚分配详细列出了所有引脚及其功能,包括电源、地、输入/输出、模拟输入等。
参数特性包括工作电压、工作频率、封装类型等,此型号的工作电压为2.0V至3.6V,工作频率为72MHz,封装类型为LQFP64。
功能详解部分介绍了微控制器的内部结构和工作原理,包括内核、存储器、外设等。
应用信息说明了该微控制器适用于工业控制、消费电子、医疗设备等领域。
封装信息显示该器件采用64引脚的LQFP封装,具有较好的热性能和电气性能。
PIM479 价格&库存
很抱歉,暂时无法提供与“PIM479”相匹配的价格&库存,您可以联系我们找货
PIM479
  • 12+119.4300112+15.49595
