PIM480
PIM480
    PIMORONI
    SGP30 空气质量 传感器 Pimoroni 分线板 平台评估扩展板
PIM480 数据手册
SGP30 Air Quality Sensor Breakout PIM480 Measure indoor air quality—total volatile organic compounds (TVOC) and equivalent CO2 (eCO2)—with this digital sensor for Raspberry Pi and Arduino. The SGP30 sensor measures two different types of gases: volatile organic compounds (like hydrocarbons) and equivalent carbon dioxide (H2 level is used as a proxy for this). The sensor does some nifty real-time baseline compensation to give you the most accurate readings, with just a 10-15% margin of error and minimal drift through time. It's also compatible with our fancy Breakout Garden, where using breakouts is as easy just popping it into one of the six slots and starting to grow your project, create, and code. Important! The sensor has a PTFE membrane over it (it looks like a slightly translucent white film). Do not peel it off! This is a gas-permeable membrane that is required for the sensor to function as intended. Features ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ Sensiron SGP30 TVOC and eCO2 sensor TVOC sensing from 0-60,000 ppb (parts per billion) CO2 sensing from 400 to 60,000 ppm (parts per million) 1Hz sampling rate I2C interface(address 0x58) 3.3V or 5V compatible Reverse polarity protection Raspberry Pi-compatible pinout (pins 1, 3, 5, 7, 9) Compatible with all models of Raspberry Pi, and Arduino Python library Datasheet Kit includes ▪ ▪ ▪ SGP30 breakout 1x5 male header 1x5 female right angle header We've designed this breakout board so that you can solder on the piece of right angle female header and pop it straight onto the bottom left 5 pins on your Raspberry Pi's GPIO header (pins 1, 3, 5, 6, 9). Software We've put together a Python library that you can use to read data from your SGP30 breakout, and provided an example of how to use the library. Notes ▪ ▪ When you first set the sensor running, it takes some time to warm up (up to a minute) before returning readings Dimensions: 19x19x3mm (LxWxH) https://shop.pimoroni.com/products/sgp30-air-quality-sensor-breakout/12-12-19
PIM480 价格&库存
很抱歉,暂时无法提供与“PIM480”相匹配的价格&库存,您可以联系我们找货
PIM480
  • 1+189.328851+24.56527
库存:179
