PIM487
PIM487
    PIMORONI
    自动化 接口 Raspberry Pi 平台评估扩展板
PIM487 数据手册
          Automation HAT Mini  PIM487  Automate your world with Automation HAT Mini! Monitor and control up to 24V systems and see their status on the gorgeous full-colour display.     Don't be fooled by its size... Automation HAT Mini packs a whole bunch of functionality in. It has a relay, 3x buffered inputs 3x outputs, and 3x analog inputs, all 24V-tolerant. Last but not least, it has a beautiful 0.96" full-colour IPS LCD to display the status of your systems. Automation HAT Mini is perfect for home automation projects, giving your greenhouse intelligent sprinklers, for scheduling your fish feeding, or for controlling low-voltage lighting systems. Features             0.96" colour LCD (160x80) 1 x 24V @ 2A relay (NC and NO terminals) 3 x 12-bit ADC @ 0-24V (ADS1015) (±2% accuracy) 3 x 24V tolerant buffered inputs 3 x 24V tolerant sinking outputs 3.5mm screw terminals Pimoroni breakout-compatible pin header Mini HAT-format board Fully-assembled (no soldering required) Compatible with all 40-pin header Raspberry Pi models Python library Dimensions: 65x30x16.8mm Automate your world! All of the inputs and outputs, and the relay, on Automation HAT Mini are 24V-tolerant and many low-voltage systems in home devices (and also in cars) run on either 12V or 24V. Automation HAT Mini is a great way to monitor and control them. Use the buffered inputs to sense the on/off state of your devices, or get more granularity with the analog inputs that measure the input voltage with 12-bit accuracy. The sinking outputs can sink a total of 500mA across the three channels. For higher-current loads, you can use the relay that can tolerate up to 2A at 24V, and take advantage of the normally-open or normally-closed sides to give the correct failover state. We've added a female header on the underside of the board with the correct pinout for our Pimoroni breakout range. This opens up a whole host of nifty possibilities! Pop an I2C Breakout Extender into the header, and then you can easily pop in one of our     breakouts. No soldering necessary! Use an LTR-559 Light and Proximity Sensor to turn a device on automatically when it gets light or dark, or a BME280 Temperature, Pressure, and Humidity Sensor to trigger at a specific temperature or humidity threshold. Software As usual, we've made a super-simple to use Python library to take advantage of all of Automation HAT Mini's functions, with examples to get you started. We've added support for the 0.96" LCD to our Automation HAT library so, when you run the installer, everything you need will be set up and installed. Nifty! Our examples show you how to use all of the different functions on Automation HAT Mini and how to display their status on the LCD. Notes      Loads for the outputs should be switched on the ground side, i.e. 12/24V (from supply) -> load > output terminal -> ground (from supply) The relay can tolerate up to 2A each and should be switched on the high side The sinking outputs can sink a maximum 500mA total across the 3 outputs, so if you use a single channel you can sink the whole 500mA across it. The accuracy of the ADC is ±2%. Do not use to switch mains voltages!   https://shop.pimoroni.com/products/automation‐hat‐mini/4‐1‐20
PIM487
物料型号:PIMORONI PIM487
器件简介:自动化迷你帽(Automation HAT Mini),用于监控和控制高达24V的系统,并在全彩显示屏上查看它们的状态。
引脚分配:包括1个24V @ 2A继电器(NC和NO端子)、3个12位ADC @ 0-24V(ADS1015)(±2%精度)、3个24V耐受缓冲输入、3个24V耐受下拉输出、3.5mm螺钉端子、Pimoroni扩展兼容引脚。
参数特性:0.96英寸彩色LCD(160x80分辨率)、24V耐受、兼容所有40针引脚的树莓派模型、Python库。
功能详解:自动化迷你帽具有继电器、3个缓冲输入、3个输出和3个模拟输入,所有这些都可耐受24V。它还具有一个0.96英寸的全彩IPS LCD显示屏。
应用信息:适合家庭自动化项目,例如智能喷灌系统、定时喂鱼或控制低压照明系统。
封装信息:完全组装(无需焊接)、尺寸为65x30x16.8mm。
软件:提供了一个易于使用的Python库来利用自动化迷你帽的所有功能,并附有示例以帮助开始使用。
PIM487 价格&库存
很抱歉,暂时无法提供与“PIM487”相匹配的价格&库存,您可以联系我们找货
