PIM488
PIM488
    PIMORONI
    Picade X HAT 街机游戏套件 RetroPie MCU
PIM488 数据手册
          Picade Console   PIM488 Power-up your TV with Picade Console! It's a compact, Raspberry Pi-powered retro games machine with authentic arcade controls that plugs right into your TV, monitor, or other HDMI display. Picade Console is fight stick-style arcade console that riffs off our larger Picade with the same retro feel, same joystick and buttons, dedicated power button, and driven by the same powerful combo of the Raspberry Pi and Picade X HAT USB-C. It's beautifully packaged, comes with stickers and a neon-infused A3 Picade Console poster, and full assembly instructions.     It comes in kit form and takes an hour or two to build. The enclosure is made from powder-coated MDF and acrylic, giving it an authentic arcade look and feel. All you'll need to add is a Raspberry Pi, USB-C power supply, HDMI cable, and micro-SD card. Features           Compatible with Raspberry Pi 4 Black, powder-coated panels Acrylic console with retro artwork Push-fit arcade buttons Joystick with black ball top Speaker (3W, 4Ω, 2.5" driver) Easy access with removable back panel Dedicated illuminated power button Grippy rubber feet Dimensions (assembled): 245x120x140mm Picade X HAT USB-C features           Easy DuPont connectors for buttons and joystick Push-fit speaker terminals I2S audio DAC with 3W amplifier (mono) USB-C powered Power management, power switch pins, and power button Dedicated Picade Plasma Button connector 4-way joystick inputs 6 player buttons 4 utility buttons Metal standoffs to hold your Picade X HAT USB-C securely Extras   Picade Console poster / assembly instructions Picade stickers     Compact retro gaming Picade Console is more compact and easier to build, but has a bunch of features liked a dedicated power button, better cable routing out the back of the console with a panelmount USB-C connector for power, and retro-themed artwork. Picade X HAT USB-C is packed full of useful features. We use simple DuPont connectors that just push in rather than fiddly screw terminals, and the speaker terminals are easy push-fit connectors. There's dedicated power management on-board Picade X HAT USB-C; just plug your USB-C power supply into the back of Picade Console and it'll power your Pi through the Picade X HAT USB-C. The power button connected to the HAT means that once your Pi is safely shutdown, the power will be cut completely to the Pi. A simple press of the power button will boot your Picade Console up again. Software setup We recommend the RetroPie operating system for your Picade. You can download it from the RetroPie website and then burn it to a micro-SD card with Etcher. Connect a USB keyboard to your Pi, and connect to Wi-Fi in the RetroPie menu. Press F4 to exit to the terminal and then type curl https://get.pimoroni.com/picadehat | bash to run the Picade HAT installer. Reboot your Pi, if it doesn't prompt you to. Press the "Alt" key on your keyboard and then select "Configure input" to configure your Picade Console's controls. You'll find that the sound and power button should both be working now too!     https://shop.pimoroni.com/products/picade‐console/4‐2‐20
PIM488
- 物料型号:Picade Console - 器件简介:Picade Console 是一款小巧的、由 Raspberry Pi 提供动力的复古游戏机,具有真实的街机控制,可以直接连接到您的电视、监视器或其他 HDMI 显示屏。 - 引脚分配:Picade X HAT USB-C 配备了易于使用的 DuPont 连接器用于按钮和操纵杆,以及用于扬声器的推入式终端。 - 参数特性:兼容 Raspberry Pi 4,黑色粉末涂层面板,亚克力控制台带复古艺术作品,推入式街机按钮,带黑色球顶的操纵杆,3W、4Ω、2.5" 扬声器驱动器。 - 功能详解:Picade Console 配备了专用的照明电源按钮和防滑橡胶脚垫。尺寸(组装后):245x120x140mm。 - 应用信息:推荐使用 RetroPie 操作系统,可以通过 RetroPie 网站下载并使用 Etcher 烧录到 micro-SD 卡。 - 封装信息:Picade Console 配备了海报/组装说明和 Picade 贴纸。
PIM488 价格&库存
很抱歉,暂时无法提供与“PIM488”相匹配的价格&库存,您可以联系我们找货
