Pico Breakout Garden Base
PIM549
An easy, solderless, swappable way to use breakouts with your Raspberry Pi
Pico - add up to six Pimoroni breakouts (4 x I2C and 2 x SPI) to the sturdy slots
and get coding and creating!
Pico Breakout Garden Base sits underneath your Pico and lets you connect up to
six of our extensive selection of Pimoroni breakouts to it. Whether
it's environmental sensors so you can keep track of the temperature and humidity in
your office, a whole host of little screens for important notifications and readouts,
and, of course, LEDs. Scroll down for a list of breakouts that are currently compatible
with our C++/MicroPython libraries!
As well as a labelled landing area for your Pico, there's also a full set of broken
out Pico connections, in case you need to attach even more sensors, wires, and
circuitry. We've thrown in some rubber feet to keep the base nice and stable and to
stop it from scratching your desk, or there are M2.5 mounting holes at the corners
so that you can bolt it onto a solid surface if you prefer.
The six sturdy black slots are edge connectors that connect the breakouts to the pins
on your Pico. There's two slots for SPI breakouts (like our 0.96" LCD
Breakout or 1.12" SPI OLED Breakout), and four slots for I2C breakouts. Because
I2C is a bus, you can use multiple I2C devices at the same time, providing they don't
have the same I2C address (we've made sure that all our breakouts have different
addresses, and we print them on the back of the breakouts so they're easy to find).
As well as being a handy way to add functionality to your Pico, Breakout Garden is
also very useful for prototyping projects without the need for complicated wiring,
soldering, or breadboards, and you can grow or change up your setup at any time.
If you would prefer your breakout setup to be a little more compact, we have a three
slot Pico Breakout Garden Pack coming soon.
Please note that breakouts are sold separately! A Raspberry Pi Pico is not
included - click here if you'd like to buy one.
Features
Six sturdy edge-connector slots for Pimoroni breakouts
4x I2C slots (5 pins)
2x SPI slot (7 pins)
Landing area with female headers for Raspberry Pi Pico
0.1” pitch, 5 or 7 pin connectors
Broken-out pins
Reverse polarity protection (built into breakouts)
99% assembled - just need to stick on the feet!
Compatible with Raspberry Pi Pico/Pico W
Schematic
About Pico Breakout Garden
Because of the way that I2C (the protocol that Breakout Garden uses) works, it
doesn't matter which slot on the Breakout Garden that you plug your breakout into.
Each I2C device has an address (you'll see it on the back of each breakout) that it
uses to identify itself to other I2C devices, so it's effectively saying "Hey, it's me,
Bob!"
We've built reverse polarity protection into our Pimoroni breakouts, meaning that
there's no magic blue smoke if you accidentally plug one in the wrong way round.
However, the correct way to plug them in is to make sure that the labels on the pins
on your breakout and the labels on each Breakout Garden slot matchup. The
markings on the base will show you which way round to plug in your Pico - just match
up the USB port with the markings on the board.
https://shop.pimoroni.com/products/pico-breakout-garden-base?variant=32369509892179 12/12/22
很抱歉,暂时无法提供与“PIM549”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+156.270511+20.30776
