PPPINWHEEL
PPPINWHEEL
    PIMORONI
    OCTOSNAP - BREAKAWAY HEADER SNAP
PPPINWHEEL 数据手册
  OctoSnap - breakaway header snapper PPPINWHEEL   Are you tired of snapping your breakaway headers down to the size you need? Do you snap one too many or one too few pins? Then this is for you! This simple kit makes breaking your headers fast and painless, simply insert your header into the gap that corresponds to the number of pins you want then snap! Everything you need is included, even an Acrylic spanner so no tools are needed! The OctoSnap will let you break your headers into the following lengths: 2 Pins, 3 Pins, 4 Pins, 5 Pins, 6 Pins, 8 Pins, 10 Pins and 12 Pins. Kit contains:      2 x Outer acrylic plates.  1 x Middle acrylic spacer.  8 x M3 Stainless steel dome nuts.  8 x 10mm Stainless M3 steel machine screws.  1 x Acrylic spanner                                                     https://shop.pimoroni.com/products/octosnap‐breakaway‐header‐snapper 6/27/2017
PPPINWHEEL 价格&库存
很抱歉,暂时无法提供与“PPPINWHEEL”相匹配的价格&库存,您可以联系我们找货
