PIM339
PIM339
    PIMORONI
    PIBOW 3 B+ (RASPBERRY PI 3 B+, 3
PIM339 数据手册
      Rainbow Ninja     Pibow 3 B+ (Raspberry Pi 3 B+, 3, & 2) Pibow. The most stylish, add-on friendly, and protective case for the Raspberry Pi 3 B+! We've redesigned Pibow to be compatible with the Raspberry Pi 3 B+, 3, and 2. Due to changes in the layout of the Raspberry Pi 3 B+, older Pibows (ones with a 3/2/B+ label) will not work ideally with Raspberry Pi 3 B+! Features  Compatible with Raspberry Pi 3 B+, 3, and 2  Fully HAT-compatible  Works great with standoffs!  Protects your beloved Pi!  Now includes a free extension layer  Etched port markings and cable escapes  Clear top and base leave Raspberry Pi visible  Leaves all ports accessible  Made from lightweight, high-quality, cast acrylic  Great for hacking and tinkering!  Made in Sheffield, UK Crafted out of ten unique layers, including a transparent top and base, that leave your beautiful Pi visible inside. Each layer is laser-cut from colourful, high-quality, cast acrylic and once stacked they securely contain a Raspberry Pi 3 B+, 3, or 2, while leaving the primary ports, including the camera port, and display port accessible. Weighing just over 90 grams, the case is lightweight and ideal for mounting to any surface. No tools are required for assembly or disassembly. The dimensions are: 99x66x30mm (WxLxH, not including bolt heads and nuts).                      https://shop.pimoroni.com/products/pibow‐for‐raspberry‐pi‐3‐b‐plus# 3‐27‐18
PIM339 价格&库存
很抱歉,暂时无法提供与“PIM339”相匹配的价格&库存,您可以联系我们找货
