SM-CVRS
SM-CVRS
    PIMORONI
    SMALL 15MM SMARTIPI TOUCH BA
SM-CVRS 数据手册
  Small - 15mm – SmartiPi Touch back cover  SM-CVRS SmartiPi Touch back cover These simple covers screw into the back VESA mounts on the SmartiPi Touch with the four included screws. They allow you to protect HAT boards and other electronic components that you might want for your project. You can choose between a 15mm deep cover and 37mm deep cover. They are made of ABS plastic and will have to be cut, drilled, or modified for your application. The case also helps protect the ethernet and USB ports on the Pi B+,2 and 3.                      https://shop.pimoroni.com/products/smartipi‐touch‐back‐cover?variant=21202189877331/ 12‐10‐18
SM-CVRS 价格&库存
很抱歉,暂时无法提供与“SM-CVRS”相匹配的价格&库存,您可以联系我们找货
