SM 100R
SM 100R
    PIMORONI
    CASE PLASTIC GRAY
SM 100R 数据手册
    SmartiPi case for Raspberry Pi    Case Only SM 100R With camera enclosure SM 200R   The SmartiPi is a versatile Raspberry Pi 2 / B+ and camera case with Lego® and GoPro® mount compatibility. Case Features            Permanently embedded 2x6 Lego® compatible plates. Included is a 6x10 Lego® compatible plate that can be snapped onto the embedded 2x6 plates. This makes the top flush. Screw together construction with 4 screws included. 3 holes which line up with 75mm vesa mounts Areas in housing for routing through zip ties and/or twine. Quick wall mount eyelets on back. Stacking features on bottom allow for stacking of multiple SmartiPi cases. ( bottom features are not Lego® compatible) Feature on housing can be used with GoPro® mounts (bolt included). Holes for DSI and CSI cable routing. Compatible with 40 pin GPIO connector (secondary strain relief must be removed, if applicable). Visual access to LEDS. Camera case features      Compatible with the official Raspberry Pi camera. Simple snap together construction. Lego® compatible back. Two screw holes for mounting. Middle hole for using third party gooseneck arms (hole is same size as hole on camera PCB). Please note: We've had reports that many HAT boards will not fit inside this case!                                    https://shop.pimoroni.com/products/smartipi-case-for-raspberry-pi 3/31/2017
SM 100R 价格&库存
很抱歉,暂时无法提供与“SM 100R”相匹配的价格&库存,您可以联系我们找货
