SP027
SP027
    PIMORONI
    RP2040 - ARM® Cortex®-M0+ MCU 32-位 评估板 - 嵌入式
SP027 数据手册
RP2040 Stamp Round Carrier SP027 The Round Carrier is a reference design for the RP2040 Stamp as well as a full-fledged round RP2040 dev board. The Carrier comes with a combo 3in-1 SMD/TH/FlexyPin Stamp footprint, you can solder the Stamp directly to the Carrier, use 2mm pin headers + sockets to be able to plug it in and out, or use FlexyPins to pop the Stamp in and out of the Carrier would soldering the Stamp. This way the Carrier also acts as a great Stamp flashing and testing jig. The Carrier extends the functionality of the Stamp by adding a ring of 16 Neopixels, an on/off switch, a LiPo connector, USR and PWR LEDs, two user buttons, and a USB Type-C connector. You can use the Carrier in sewing using conductive thread or using alligator clips. By using the RP2040 Stamp Round Carrier, you get everything that comes with the Stamp itself:       8MB of FLASH 500mA 3.3V LDO A Neopixel LiPo supply and charging circuit (with charging LED) A reset button 12MHz crystal On top of that you get:          A ring of 16 Neopixels Combo 3-in-1 Stamp footprint (SMD/TH/FlexyPin) Sewing (conductive thread) and alligator clip-friendly pads An on/off switch 3.7/4.2V LiPo connector USR LED Power (3.3V) LED Two user buttons USB Type-C connector If you have the LiPo and USB Type-C connected, the battery will begin charging. The pins are not 5V tolerant. What you get   The RP2040 Stamp Round Carrier board A pinout and functionality reference sheet https://shop.pimoroni.com/products/rp2040-stamp-round-carrier 12-7-2022
SP027 价格&库存
很抱歉,暂时无法提供与“SP027”相匹配的价格&库存,您可以联系我们找货
SP027
  • 1+103.663591+13.45027
库存:14
