I000951
I000951
    PIMORONI
    SUGRU (8 PACK)
I000951 数据手册
    Sugru   3 pack SUGRU-001 8 pack SUGRU-002     Sugru is the exciting new self‐setting rubber that can be formed by hand. It moulds like play‐ dough, bonds to almost anything and turns into a strong, flexible silicone rubber overnight.  Developed by a team of product designers and material scientists, sugru's patented  technology is unique in its combination of hand‐formability, self‐adhesion and flexibility  when cured. It feels like modelling clay, and it's that easy to use too. Once cured, its durable  properties mean it's comfortable in extreme environments from the dishwasher to the ocean  in Antarctica.          What is Sugru?   Hand formable: Sugru can be formed and shaped by hand for up to 30 minutes once it has been  removed from its packaging.   Sticks to almost anything: sugru is designed to stick to as many other materials as possible. It  forms a strong bond to aluminium, steel, ceramics, glass, wood and other materials including  some plastics like perspex and ABS and rubbers like silicone and butyl rubber.   Air cures at room temperature: Sugru is like modelling clay when you take it from its pack. Once  it's exposed to air, it cures to a tough flexible silicone overnight using the moisture in the air.  Working time = 30 mins. Cure time = 24hrs (3‐5 mm deep)   Strong + durable = great outdoors: Sugru is strong and durable. Once cured, it will also stand up  to anything the weather throws at it, wet or dry, hot or cold it will be great. It also won't fade in  the sun and it's fine with sea water too!   Flexible when cured: When sugru cures, it's flexible rather than rigid. Which means that you can  repair things that need to be able to move like textiles, cables, or shoes. It's also electrically  insulating ‐ how awesome is that?   Soft touch & grippy: As sugru is a silicone rubber, it feels soft to touch when it has cured, but is  also grippy. This makes it perfect for handles and grips as it is comfortable but non‐slip.   Stable at high and low temperatures: Sugru is resistant from ‐50°C to +180°C. It gets hot and  cold but it won't get softer or harder or melt.   Waterproof: Once it's cured, sugru is pretty much like other silicones ‐ so it's completely  waterproof. It's easy to clean with soap and water, and it's durable in the harsh conditions of  your washing machine and dishwasher, and even in the sea.   Removable: Once cured, sugru can be removed by cutting it off with a sharp knife. Remove any  residue with fingernails and tissue paper. (from non‐porous materials)    Sugru can be mixed to produce an endless range of colours either to add flair or match the colour of an  object you're fixing, check out this nifty chart:  https://shop.pimoroni.com/products/sugru 4/13/2017
I000951 价格&库存
很抱歉,暂时无法提供与“I000951”相匹配的价格&库存,您可以联系我们找货
