Make Everything Magnetic —
Sugru + Magnets Kit
/SUGRU-003
Attach anything to anything with magnets + Sugru!
This kit turns you into a product designer in your own home.
By simply attaching magnets, you'll make so many things in your life easier to use.
What's inside:
Three 5g single-use packs of Pitch Black Sugru
Four bespoke neodymium magnets
One awesome booklet full of projects and tips to get you started
All lovingly packed in a handy Sugru tin
Note: if you store your unopened packs of Sugru in the fridge, it extends the number of
months left to use by x3!
Sugru is the incredible new self-setting rubber for fixing and improving your gadgets and
tools and for tricky little fixes in your engineering projects.
Sugru is formed by hand or with simple tools. It feels like play dough, and it's that easy
to use too. It bonds to almost anything and turns into a strong, flexible silicone rubber
overnight. Once cured, its durable properties mean it's comfortable in extreme
environments from the dishwasher to the ocean to Antarctica.
Sugru is designed to stick to as many other materials as possible including aluminium,
steel, ceramics, glass, wood, Perspex, and ABS and rubbers like silicone and butyl
rubber. As Sugru is a silicone rubber, it feels soft to touch when it has cured, and is also
grippy. This makes it perfect for handles, grips, pads and flexible waterproof repairs.
Once cured, in most cases, you can remove Sugru with a sharp knife and then remove
residue with tissue paper.
Top 10 uses of Sugru with gadgets and electronics:
Repair and strengthen damaged cables
Mount components semi-permanently e.g. webcams / microphones / wires / switches
Replace missing feet on speakers, laptops etc.
Mount components, and add feet to PCBs
Repair casings / housings on computers and earphones
Insulate wires
Strengthen attachments, protect against vibration
Enclose prototype electronics, make them waterproof
Add feet under hard drives to allow air to circulate underneath
Make awesome custom housings for USB flash drives
Please note: These kits are not toys and should be kept out of the reach of
children. The magnets are strong so please handle with care!
https://shop.pimoroni.com/products/make‐everything‐magnetic‐sugru‐magnets‐kit 3‐7‐18
很抱歉,暂时无法提供与“SUGRU-003”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 9+139.340289+18.07929
