7 Cell Cluster Concentrator Optic - Part No. 263
Designed for low profile, high power, Lambertian LEDs
High light collection efficiency of >85%
Precision moulded in optical grade Polycarbonate for thermal
stability and system durability
Part of the Polymer Optics “Modular LED Optics”® range
Typical dimensional tolerances
to +/-0.2mm
design, based on a hexagonal format,
allows maximum packing density and
assembly flexibility
In order to determine if the particular beam properties and performance of this optic are suitable for
your application with your chosen LED type, POL suggests that you obtain samples from POL or their
distributors for your own product testing, as properties may vary with different LED types.
Due to continuous product improvement, POL reserve the right to change specifications without notice.
© Copyright Polymer Optics Limited 2016
Beam waist Ø12mm
Typical Applications:
Beam insertion into optical fibre bundles
Beam insertion into edge of lightguides
High intensity illumination of small objects for inspection and microscopy
很抱歉,暂时无法提供与“263”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 25+130.16255
- 50+127.34040
- 国内价格
- 1+133.07843
- 25+130.16255
- 50+127.34040
