MCPCB for 7 Cell Optic – Part No. 282
Compatible with all POL Low Profile series 7 Cell Cluster
optics – 261, 262, 263, 264
The 282 MCPCB is designed to accommodate a wide
number of LED types with a 3535 package size, including:
Cree XP types
SSC Z5
LG 3535 packages
LEDs wired in series
The 282 MCPCBs can be provided by POL to support
customer prototyping and luminaire production.
Part of the Polymer Optics “Modular LED Optics”® range
Dia. 40mm x 1.6mm Thick
Typical dimensional
tolerances to +/-0.2mm
1 x 3mm Hole for Wire Feed Through
3 x 1.6mm Holes to Locate Optic Legs
In order to determine if the particular beam properties and performance of this optic are suitable for
your application with your chosen LED type, POL suggests that you obtain samples from POL or their
distributors for your own product testing, as properties may vary with different LED types.
Due to continuous product improvement, POL reserve the right to change specifications without notice.
© Copyright Polymer Optics Limited 2016
很抱歉,暂时无法提供与“282”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+42.61343
- 2+41.82197
- 5+40.40569
- 25+39.41638
- 50+38.94775
- 国内价格
- 100+47.31423
- 500+42.58218
- 国内价格
- 2+41.82197
- 5+40.40569
- 25+39.41638
- 50+38.94775
