543-W
543-W
    POLYMEROPTICS(聚合物光学)
    OFFICE - WHITE
543-W 数据手册
POLYMER OPTICS LTD. The Hall, Priory Hill, Rugby Rd. Woolston, CV8 3FZ, England Tel/Fax +44 (0) 2476 937394 www.polymer-optics.co.uk POL Part No.543 Office Lens The Office lens is designed for passive infra-red (PIR) detection in applications where the detector is usually mounted on low ceilings, where minor-motion detection is important: typically offices, washrooms, corridors, cloakrooms and entrance halls. The lens uses POL's patented free-form technology to ensure the zones are sharply focused and distortion free. The lens has a 1.3:1 aspect ratio, therefore when mounted at 2.4m height, the lens projects 67zones into a 6.2m diameter floorspace. The standard lens is moulded with a rectangular flange but we can crop the flange to your desired shape. Applications PIR detection for offices, shops, washrooms. corridors, and most domestic applications lighting control Alarm and security presence detection Fan control Diagram shows theoretical zone plot for detector mounted 2.4m above floor*. Mounting height can be adjusted as required *assuming a LHi1128 pyro is used at the nominal focal distance of 12.5mm. Diagram shows theory behind free-form lens design © Polymer Optics Ltd 2015 Page 1 of 2 General layout. All dimensions in millimetres. Third angle projection 64 X X 32 PYRO ELEMENT POSITION (TYP. PYRO LHi1128 QUAD) SECTION PART NO. 543C DESCRIPTION CLEAR HDPE MATERIAL 543W WHITE HDPE MATERIAL X-X 38.0 All of our lenses are designed using 3D ray-tracing software where we can optimise the performance and minimise optical distortion. For the simulation on the left we have traced rays from the detector to the room and this allows us to analyse the zone shape. It is important to ensure there is minimal zone distortion and zero zone overlap. For the simulation on the right we have traced rays from the room to the detector so that we can analyse the signal response. Here it is important to ensure that the signal is reasonably uniform across all the zones. © Polymer Optics Ltd 2015 Page 2 of 2
543-W 价格&库存
很抱歉,暂时无法提供与“543-W”相匹配的价格&库存,您可以联系我们找货
