707-B
707-B
    POLYMEROPTICS(聚合物光学)
    PIR DOME LENS CURTAIN-BLACK
707-B 数据手册
DOME CAP LENS HORIZONTAL CURTAIN (HC) FOR PIR MOTION SENSING OVERVIEW High performance motion detection lens for security and lighting applications. Horizontal curtain (HC) beam pattern with 100deg FOV and up to 12m range. Ideal for portable security devices where pet immunity is required. Pyro not included. FEATURES Designed to press onto standard T05 pyro Dome Cap Lens HC Automatically sets correct focal distance Fresnel lenses fo maximise IR collection Spherical shape creates natural rigidity Designed using optical ray-tracing software Compact shape with clearance for pcb components Typical mounting method: 20x1mm o-ring stretched around lens flange. PCB screwed to housing via pillars. Orientation tab sits in channel next to fixing pillar. Available in natural, white and black colours Part Number 707-N 707-W 707-B Drawing A3-10707 A3-10707 A3-10707 Colour Natural White Black Theoretical zone plot. Optimum range is 8m. Maximum Range 12m depending on electronic gain 10m 8m Typical application 1: Bookshelf device, mounted 1.5m above floor, detects humans, immune to pets. Typical application 2: Ceiling mounted corridor detection. Ideal for ceiling mounted luminaires. Detector is immune from air movement around windows and doors. c 2019 Polymer Optics Limited ALL DIMENSIONS IN mm Polymer Optics Ltd, The Hall, Priory Hill, Rugby Road, Wolston, Coventry, CV8 3FZ, England Tel: +44 (0)2476 937394 www.polymer-optics.co.uk FOR PIR MOTION SENSING FEATURES Designed to press onto standard T05 pyro Horizontal curtain and circular beam patterns Choice of profile shape to suit product styling Designed using optical ray-tracing software Compact shape with clearance for pcb components Available in natural, white and black colours Dome Cap Lens HC Dome Cap Lens 360 Flat Cap Lens HC Flat Cap Lens 360 APPLICATIONS Office and household lighting control Motion detection for security applications Individual luminaire switching Fan and air conditioning control Control panel illumination for appliances Vending machines, ATM’s, streetlights Lens pushes onto TO5 pyro. Slot in flange ensures correct orientation with pyro. Casing traps lens flange so that lens is held securely. ‘O’ ring can be used to seal. Lens has clearance for PCB components. Sealed lens environment prevents false detections from contamination and air movement. Indicator LED can project light through lens. Low voltage sensor modules are available. Sensor modules have analogue pyro with switching circuit and sensitivity sdjustment. Can be combined with relay module for mains switching. Modules can be used for alarm activation or lighting. Cap lenses can be ordered to fit most of the leading pyro-electric sensor brands such as Excelitas, Nicera, Murata and Panasonic. The lens presses onto the T05 cannister and is held at the correct focal distance. Small and compact, these lenses are suitable for numerous security and lighting applications, in the office, or around the home. Available in two beam pattern versions, horizontal curtain (HC) and 360deg ceiling, there is a lens suitable for every application. Polymer Optics Ltd, The Hall, Priory Hill, Rugby Road, Wolston, Coventry, CV8 3FZ, England Tel: 02476 937394 www.polymer-optics.co.uk
707-B 价格&库存
很抱歉,暂时无法提供与“707-B”相匹配的价格&库存,您可以联系我们找货
