713-N
713-N
    POLYMEROPTICS(聚合物光学)
    PIR FLAT LENS CEILING-NATURAL
713-N 数据手册
FLAT CAP LENS CEILING 360 FOR PIR MOTION SENSING OVERVIEW Motion detection lens for security and lighting applications. 360deg beam pattern with 100deg FOV within 6m diameter area. Lens can be flush mounted with product housing - ideal for devices where strong aesthetic appearance is important. FEATURES Flat Cap Lens 360 Designed to press onto standard T05 pyro Fresnel lenses fo maximise IR collection Uses POL’s unique free-form Fresnel system Designed using optical ray-tracing software Compact shape with clearance for pcb components Available in natural, white and black colours Part Number 713-N 713-W 713-B Drawing A3-10713 A3-10713 A3-10713 Colour Natural White Black Note: White material has 25% lower IR transmission than natural material. Black material has 35% lower IR transmission than natural material. Typical mounting method: 20x1mm o-ring stretched around lens flange. PCB screwed to housing via pillars. Orientation tab sits in channel next to fixing pillar. TYPICAL PYRO EXCELITAS PYQ 1348 QUAD ELEMENT PYRO. IF POSSIBLE, CHOOSE SMALL ELEMENT VERSION (DIMENSIONS ARE BASED ON THIS CHOICE OF PYRO) c 2017 Polymer Optics Limited ALL DIMENSIONS IN mm Polymer Optics Ltd, The Hall, Priory Hill, Rugby Road, Wolston, Coventry, CV8 3FZ, England Tel: 02476 937394 www.polymer-optics.co.uk FOR PIR MOTION SENSING FEATURES Designed to press onto standard T05 pyro Horizontal curtain and circular beam patterns Choice of profile shape to suit product styling Designed using optical ray-tracing software Compact shape with clearance for pcb components Available in natural, white and black colours Dome Cap Lens HC Dome Cap Lens 360 Flat Cap Lens HC Flat Cap Lens 360 APPLICATIONS Office and household lighting control Motion detection for security applications Individual luminaire switching Fan and air conditioning control Control panel illumination for appliances Vending machines, ATM’s, streetlights Lens pushes onto TO5 pyro. Slot in flange ensures correct orientation with pyro. Casing traps lens flange so that lens is held securely. ‘O’ ring can be used to seal. Lens has clearance for PCB components. Sealed lens environment prevents false detections from contamination and air movement. Indicator LED can project light through lens. Low voltage sensor modules are available. Sensor modules have analogue pyro with switching circuit and sensitivity sdjustment. Can be combined with relay module for mains switching. Modules can be used for alarm activation or lighting. Cap lenses can be ordered to fit most of the leading pyro-electric sensor brands such as Excelitas, Nicera, Murata and Panasonic. The lens presses onto the T05 cannister and is held at the correct focal distance. Small and compact, these lenses are suitable for numerous security and lighting applications, in the office, or around the home. Available in two beam pattern versions, horizontal curtain (HC) and 360deg ceiling, there is a lens suitable for every application. Polymer Optics Ltd, The Hall, Priory Hill, Rugby Road, Wolston, Coventry, CV8 3FZ, England Tel: 02476 937394 www.polymer-optics.co.uk
713-N
物料型号包括713-N(自然色)、713-W(白色)、713-B(黑色)。
器件简介为用于安全和照明应用的运动检测镜头,具有360度光束模式和100度视场角,适用于6米直径区域内。
引脚分配未在文档中明确说明。
参数特性包括自然色材料的红外透射率最高,白色材料的红外透射率比自然色低25%,黑色材料的红外透射率比自然色低35%。
功能详解包括设计用于压在标准T05热释电菲涅尔透镜上以最大化红外收集,使用POL的独特自由形态菲涅尔系统,使用光学射线追踪软件设计,具有紧凑的形状和为PCB组件预留的空间。
应用信息包括办公和家庭照明控制、安全应用的运动检测、个别灯具开关、风扇和空调控制、设备控制面板照明、自动售货机、ATM、街灯等。
封装信息包括自然色、白色和黑色三种颜色,以及镜头可以压在T05热释电传感器上,并通过镜头法兰上的槽确保与传感器的正确对齐。
713-N 价格&库存
很抱歉,暂时无法提供与“713-N”相匹配的价格&库存,您可以联系我们找货
