AS01808AO-SC18-WP-R
AS01808AO-SC18-WP-R
    PUIAUDIO
    8 Ohms 通用 扬声器 1 W 420 Hz ~ 14 kHz 顶部 矩形
AS01808AO-SC18-WP-R 数据手册
This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2017, PUI Audio Inc. Data Sheet AS01808MS-SC18-WP-R PUI Audio’s Mobile Series line of speakers and receivers is designed for cuttingedge applications such as smart watches and pendants, Wi-Fi enabled security devices and action cameras, mobile radios and smart phones, as well as IoT devices. Each Mobile Series product features an IP67-rated face for protection against dust and water ingress. The eight ohm 18mm x 13mm AS01808MS-SC18-WP-R speaker is designed for high fidelity audio reproduction in the thinnest size possible—only 2.5mm thick! Spring contacts offer quick electrical connection. Features: • PEEK diaphragm for flat frequency response • 88 dB output (2V @ 10cm) • High-energy neodymium motor • Only 2.5 mm thick • Dustproof and waterproof IP67-rated face Specifications Parameters Rated Input Power Max Input Power Impedance Sensitivity (SPL @ 2.37V/10cm) At 2 kHz in 1cc enclosure Resonant Frequency (in 1cc enclosure) Frequency Range Frame Material Magnet Material Weight Environmental Protection Rating Values 0.5 1 8 ± 15% Units Watts Watts Ohms 88 ± 3 dB 850 ± 20% 500 ~ 20,000 PPA NdFeB 1.8 IP67 Hz Hz Grams - PUI Audio, Inc. A Projects Unlimited Company, 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2017, PUI Audio Inc. Specifications (continued) Buzz, Rattle, etc. Polarity Storage Temperature Operating Temperature Should not be audible with 2V sine sweep from 500 Hz to 10 kHz installed in a 1cc enclosure When positive voltage is applied to the positive terminal, the diaphragm will move outward -40 ~ +85 -20 ~ +70 - °C °C Measurement Method (measured with 2V, Temperature: 15 ~ 35°C, Relative Humidity: 45%~85%) Frequency Response (measured with 2V @ 10cm in 1cc enclosure) PUI Audio, Inc. A Projects Unlimited Company, 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2017, PUI Audio Inc. Impedance Response (Measured with speaker in a 1cc enclosure) Reliability Testing Type of Test High Temperature Test Low Temperature Test Humidity Test Temperature Cycle Testing Vibration Test Drop Test Test Specifications 96 hours at +85°C ± 3°C followed by two hours in normal room temperature 96 hours at -40°C ± 3°C followed by two hours in normal room temperature 96 hours at +55°C ± 3°C with relative humidity at 95% in accordance with IEC 68-2-67 The part shall be subjected to 20 cycles using the following procedure: Low temperature: -40℃±3℃ High temperature:+85℃±3℃ Cycle: 30 mins at High, 10 seconds High to Low, 30 mins at Low, 10 seconds minutes Low to High 10 to 55 to 10 Hz sine sweep, per minute @ 1.5mm amplitude 2 hours in each axis X, Y, and Z Mount speaker to 150g fixture, drop fixture 1.5 meters, twice per side and twice for each corner DUTs shall be tested under each specified climatic condition for a continuous period of 100 hours at rated noise power. Speakers mounted in a 1cc back cavity; simulated program signal (IEC 268-1) with crest factor of 1.8~2.2 ,in rated frequency range; high pass 12dB/Oct or steeper, cut off at 850Hz. Refer to IEC 268-5 Load Test After each test, the speaker’s SPL shall be ±3 dB of the original SPL PUI Audio, Inc. A Projects Unlimited Company, 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2017, PUI Audio Inc. Dimensions (Bottom contact is positive on the far right drawing below) Packaging PUI Audio, Inc. A Projects Unlimited Company, 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2017, PUI Audio Inc. Revision - Specifications Revisions Description Released from Engineering Note: 1. Unless otherwise specified: A. All dimensions are in millimeters. B. Default tolerances are ±0.5mm and angles are ±3°. 2. Specifications subject to change or withdrawal without notice. 3. This part is RoHS 2011/65/EU Compliant. PUI Audio, Inc. A Projects Unlimited Company, 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 Date 11/20/2017
AS01808AO-SC18-WP-R 价格&库存
很抱歉,暂时无法提供与“AS01808AO-SC18-WP-R”相匹配的价格&库存,您可以联系我们找货
AS01808AO-SC18-WP-R
  • 1+33.542241+4.33920
  • 5+29.349465+3.79680
  • 10+26.9036710+3.48040
  • 25+23.4970425+3.03970
  • 40+21.8374040+2.82500
  • 50+21.4006550+2.76850
库存:98
