AS09008PO-11-WR-R
AS09008PO-11-WR-R
    PUIAUDIO
    8 Ohms 通用 扬声器 5 W 180 Hz ~ 10 kHz 顶部 椭圆,矩形框架
AS09008PO-11-WR-R 数据手册
This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2019, PUI Audio Inc. Data Sheet AS09008PO-11-WR-R Specifications Parameters Rated Input Power Max Input Power Impedance Sensitivity (SPL @ 1W/50cm) At 0.8, 1.0, 1.2, 1.5 kHz Resonant Frequency Frequency Range Frame Material Magnet Material Weight Buzz, Rattle, etc. Polarity Storage Temperature Operating Temperature Values 5 8 8 ± 15% Units Watts Watts Ohms 85 ± 3 180 ± 20% Fo ~ 10,000 Steel Ferrite 98 Must be normal at sine wave Fo20kHz, 6.32 Cone will move forward with positive+ current to positive terminal dB Hz Hz Grams -20 ~ +65 -20 ~ +65 °C °C Frequency Response (measured with 2.83V @ 50cm) PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 - This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2019, PUI Audio Inc. Reliability Testing Type of Test High Temperature Test Low Temperature Test Humidity Test Test Specifications 96 hours at +65°C ± 3°C followed by three hours in normal room temperature 96 hours at -20°C ± 3°C followed by three hours in normal room temperature 96 hours at +40°C ± 3°C with relative humidity at 90% followed by 6 hours in normal room temperature The part shall be subjected to 5 cycles using the following procedure: Temperature Cycle Testing Vibration Test Frequency 30 ± 15Hz, Amplitude 1.5mm for 3hr Drop Test 100cm free fall onto concrete, x2 Load Test Rated power for 96hrs After each test, the speaker’s SPL shall be ±3 dB of the original SPL PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2019, PUI Audio Inc. Dimensions PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2019, PUI Audio Inc. Packaging Specifications Revisions PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2019, PUI Audio Inc. Revision Description Date - Released from Engineering 5/1/2020 Note: 1. 2. 3. 4. Unless otherwise specified: A. All dimensions are in millimeters. B. Default tolerances are ±0.5mm and angles are ±3°. Specification to change or withdraw without notice. Speaker face has been treated for water resistance. This part is RoHS 2015/863/EU Compliant. PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 Customer Approval (Date & Signature)
AS09008PO-11-WR-R 价格&库存
很抱歉,暂时无法提供与“AS09008PO-11-WR-R”相匹配的价格&库存,您可以联系我们找货
