SPECIFICATIONS
PARAMETERS
RATED VOLTAGE
OPERATING VOLTAGE RANGE
RATED CURRENT (MAX)
COIL RESISTANCE
MINIMUM SPL @ 10 CM
RESONANT FREQUENCY
OPERATING TEMPERATURE
STORAGE TEMPERATURE
HOUSING MATERIAL
TERMINAL MATERIAL
WEIGHT
VALUES
UNITS
1.5
1~3
30
16 4
85
2,500 200
-20 ~ +70
-30 ~ +80
COPPER
Sn PLATED COPPER
5
Vp-p
Vp-p
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
REVISION HISTORY
LTR
DESCRIPTION
DATE
RELEASED FROM ENGINEERING
9/26/2018
2003, Projects Unlimited Inc.
mA
OHM
dBA
Hz
C
C
grams
10 0.2
8.5
7
11.6
APPROVED
14
REMOVABLE
WASH TAB
0.2
5
0.3
0.6 (2)
2.7 SOUND
EMISSION HOLE
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2011/65/EU COMPLIANT.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
AT-1425-TWT-3-R.idw
Designed by
Date
Checked by
Date
Approved by
T.G.
9/26/2018
B.R.
9/26/2018
E.P.
Date
Drawn Date
9/26/2018 9/26/2018
AT-1425-TWT-3-R
Transducer (Electro-Mech)
Edition
Sheet
1/1
很抱歉,暂时无法提供与“AT-1425-TWT-3-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+40.23000
- 200+16.05960
- 500+15.51960
- 1000+15.24960
