AT-3108 8 OHM
AT-3108 8 OHM
    PUIAUDIO
    SPEAKER 8OHM 100MW 82DB
AT-3108 8 OHM 数据手册
Projects Unlimited Inc. 3680 Wyse Road Dayton Ohio 45414-5802 Phone: 937-918-2200 Fax: 937-918-2206 Audio@ProjectsUnlimited.com PUI International P.O. Box 555, 1214 Vernier, Switzerland Phone: +49 (4027) 839341 Fax: +49 (4027) 90077 Part Number: AT-3108 Features Mylar cone speaker transducer P.C. Mounting - 17.5mm lead spacing 31.9mm dia x 15.1mm high Electrical Specifications Weight Case Material Operating Temperature Range Cone Material Rated Input Maximum Input Frequency Range Impedance 9.9 Grams ABS Black -20 to +60 Deg C Mylar 0.1 Watts 0.2 Watts 500 - 4,000 Hz 8 +/- 20% Ohms P.C. Pins: Tin plated copper This device has been designed for a wide variety of applications where small size is important. The low profile and broad frequency range make it an ideal choices for keyboards, handheld instruments and other miniaturized systems For application notes and detail drawing specifications, please consult www.projectsunlimited.com. Specifications subject to change without notice. © 2000, Projects Unlimited Inc., All Rights Reserved.
AT-3108 8 OHM 价格&库存
很抱歉,暂时无法提供与“AT-3108 8 OHM”相匹配的价格&库存,您可以联系我们找货
