This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission
of PUI Audio Inc. is prohibited.
©2021, PUI Audio Inc.
Data Sheet
UTR-16295K-TP-LWC60
Key Features
Primarily for short range detection application
Innovative acoustic material
High precision
Good directivity
Excellent consistency
Specifications
Parameters
Function
Nominal Drive Frequency
Hard Ground Sensitivity
(measuring distance 30cm)
Typical Beam Angle
Values
Transmitter/Receiver
295 ± 15
First echo: 2750 +750/-200
Second echo: 2600 +900/-1100
9±3
120
Max. Driving Voltage
12
Capacitance
Environmental Compliances
Housing Material
Operating Temperature
Storage Temperature
1,300 ± 20%
RoHS/REACH
Black Plastic (PC)
-20 ~ 70
-40 ~ 70
Test condition: T=25±3℃,H=45~75% R.H
www.puiaudio.com
Units
Dual Mode
kHz
mVp-p
Vp-p
(Max. number of
pulse: 96; Pulse
interval: 30ms)
Vp-p Continuous
Square Wave
pF
°C
°C
Dimensions
Product direction angle test
During the test, the launch angle is perpendicular to the plate as a base, then shift the
sensor to the left or right for testing.
www.puiaudio.com
Reliability Testing
Type of Test
High Temperature Test
Low Temperature Test
Humidity Test
Test Specifications
240 hours at 70 ± 2°C
240 hours at -40 ± 3°C
240 hours at 7 0 ± 2°C with relative
humidity at 90-95%
Temperature Cycle Testing
The part is subject to 100 cycles consisting
of:
-40 ± 3°C for 30 mins, raise to 70 ± 2°C
within 3 mins, keep at 70 ± 2°C for 30 mins,
and then cool to -40 ± 3°C within three
minutes
Vibration Test
Constant frequency acceleration of 20Hz
with acceleration of 4.4g in each
direction for 24 hrs. Then sweep
frequency from 10Hz to 200Hz with
acceleration of 4.4g and rising time and
falling time of 15 mins in each direction.
Drop Test
Drop 3 times in each direction, at the
height of 1.0m.
After each test, the SPL shall be ±6 dB of the original SPL after 24 hours of rest in normal
conditions.
Packaging
www.puiaudio.com
Revision
A
Specifications Revisions
Description
Released from Engineering
Note:
1.
2.
3.
4.
Unless otherwise specified:
A. All dimensions are in millimeters.
B. Default tolerances are ±0.5mm and angles are ±3°.
Specifications subject to change or withdrawal without notice.
Typical mounting is panel mount with unsupplied spring clip.
Mating connector is ZR insulation displacement connectors, such as B2B-ZR(LF)(SN)
www.puiaudio.com
Date
10/20/2022
UTR-16295K-TP-LWC60 价格&库存
很抱歉,暂时无法提供与“UTR-16295K-TP-LWC60”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+115.815151+15.00212
- 5+105.118295+13.61650
- 20+97.4889420+12.62823
- 40+94.1459140+12.19519
- 60+92.3208260+11.95878
- 100+90.15015100+11.67760
- 500+84.14434500+10.89964
- 1000+81.905101000+10.60958
- 国内价格
- 1+151.91280
- 180+60.62040
- 540+58.59000
- 1080+57.59640
