PTS-00155-211
PTS-00155-211
    PTSOLNS
    BOB FOR COMMON BOARDS KIT
PTS-00155-211 数据手册
ESP-BoB Kit 1 DESCRIPTION The ESP-BoB Kit is an unassembled kit designed to interface with ESP development boards, and other similarly sized boards. BoB stands for “Breakout Board”, which is exactly what this product does. The central double row female headers can accept many of the common microcontrollers, up to 20 rows in length and between 8 to 10 rows spacings in width (20.32 mm, 22.86 mm, 25.40 mm). The breakouts on both sides include a footprint for a row of female header, a row of male header, and a row of screw terminals. Table of Contents 1 DESCRIPTION ............................................................................................................................................................1 2 DOCUMENT REVISION HISTORY ...............................................................................................................................2 3 PRODUCT FEATURES ................................................................................................................................................3 3.1 Compatibility ....................................................................................................................................................3 3.2 Features of the ESP-BoB...................................................................................................................................4 3.3 Mark of Authenticity ........................................................................................................................................5 4 PHYSICAL PROPERTIES..............................................................................................................................................6 5 ELECTRICAL PROPERTIES ..........................................................................................................................................7 6 KIT PACKAGE CONTENTS ..........................................................................................................................................8 2 DOCUMENT REVISION HISTORY Current document revision is Rev 0. 3 PRODUCT FEATURES This section highlights notable features of the ESP-BoB Kit. 3.1 Compatibility Due to the double row female header interface, the ESP-BoB is compatible with a range of products. The board can interface any product up to 20 pins in length at standard 2.54 mm/0.1 in pitch and with three different widths. The widths are: - 8 Pin spacing = 20.32 mm 9 Pin spacing = 22.86 mm 10 Pin spacing = 25.40 mm The physical dimensions of the ESP-BoB are shown Figure 4. As an example, Figure 1 shows a commonly used ESP32 development board plugged into the ESP-BoB. This particular ESP32 development board has a row spacing of 19 pins, and a width of 10 pins (= 25.4 mm). Since the breakout of the ESP-BoB is generic, all the pins are simply numbered and not assigned. This is done because many different ESP32 development boards have a different pin assignment. Figure 1: Example application. 3.2 Features of the ESP-BoB The features of the ESP-BoB are graphically shown in Figure 2. All the pins are broken out on either side with a footprint for a row of male header pins, a row of female header pins, as well as a row of screw terminals. Additionally, there are two pinouts available for the ground planes (top and bottom combined) of the board. There are four mounting holes. Figure 2: Features of the ESP-BoB. 3.3 Mark of Authenticity Authentic PTSolns PCBs have a black solder mask color and are marked with the “PTSolns” logo in white silkscreen printing. The “Canadian Designed” symbol, consisting of the Canadian Maple Leaf with the word “Designed” underneath, can also be found on the PCB in white silkscreen printing. The “PTSolns” trademark and the “Canadian Designed” symbols are shown in Figure 3. Figure 3: The "Canadian Designed" symbol found on authentic PTSolns PCBs. 4 PHYSICAL PROPERTIES The physical properties of the ESP-BoB (PCB only) are outlined in Table 1. Table 1: Physical Properties. PCB Quantity Length Width Thickness Corner radius Weight (without headers/connectors) Color Silkscreen Value 71.4 mm 71.7 mm 1.6 mm 1.0 mm 17 g Black White Reference Figure 4 Figure 4 Figure 4 Figure 4 ---- Mounting hole diameter Mounting hole center-to-center distance along length Mounting hole center-to-center distance along width 3.2 mm 59.5 mm Figure 4 Figure 4 36.1 mm Figure 4 Lead free HASL-RoHS surface finish FR-4 base --- --- Mounting Material Figure 4: Dimensions of the ESP-BoB. 5 ELECTRICAL PROPERTIES Electrical properties are outlined in Table 2. Electrical connections made by copper traces are shown in Figure 5. Copper traces have a weight of 1 oz/ft2. Table 2: Electrical Properties. Quantity Current rating Value 0.6A Figure 5: Electrical connections of the ESP-BoB. 6 KIT PACKAGE CONTENTS The following items are included in the ESP-BoB Kit. This kit comes unassembled. This kit includes:       1pc PCB PTSolns ESP-BoB 12pcs 3.5mm 3-pin screw terminals 2pc 3.5mm 2-pin screw terminal 2pcs 2.54mm/0.1in, 1x20 pin female header 2pcs 2.54mm/0.1in, 2x20 pin female header 1pc 2.54mm/0.1in, 1x40 pin male header o User can easily break the full male header pins into two sections of 20 pins.
PTS-00155-211
物料型号:ESP-BoB Kit
器件简介:ESP-BoB Kit是一个未组装的套件,设计用于与ESP开发板和其他类似尺寸的板子接口。BoB代表“Breakout Board”,即扩展板。
引脚分配:ESP-BoB通过双排女性头接口与多种产品兼容,支持长达20针的标准2.54毫米/0.1英寸间距,并具有三种不同的宽度:8针间距20.32毫米、9针间距22.86毫米、10针间距25.40毫米。
参数特性: - 物理尺寸:长71.4毫米,宽71.7毫米,厚1.6毫米 - 重量(不含头/连接器):17克 - 颜色:黑色 - 表面处理:无铅HASL-RoHS - 电气特性:电流额定值0.6A
功能详解:ESP-BoB的两侧都有引脚扩展,包括一排男性头引脚、一排女性头引脚以及一排螺钉端子。此外,板上还有两个接地平面的引脚输出(顶部和底部合并)。
应用信息:ESP-BoB可以用于多种ESP32开发板,例如文档中展示的ESP32开发板,具有19针的行间距和10针的宽度(25.4毫米)。
封装信息:ESP-BoB Kit包括1个PCB、12个3.5毫米3针螺钉端子、2个3.5毫米2针螺钉端子、2个2.54毫米/0.1英寸1x20针女性头、2个2.54毫米/0.1英寸2x20针女性头、1个2.54毫米/0.1英寸1x40针男性头(用户可以轻松将完整的男性头引脚分成两段,每段20针)。
PTS-00155-211 价格&库存
很抱歉,暂时无法提供与“PTS-00155-211”相匹配的价格&库存,您可以联系我们找货
