PTS-00134-001
PTS-00134-001
    PTSOLNS
    内六角,梅花型,十字式,一字式,扳手(安全),Torx®,三角套筒,Tri-Wing® 螺丝刀组
PTS-00134-001 数据手册
Precision S2 Magnetic 25-in-1 Screwdriver Set 1 DESCRIPTION This precision screwdriver set contains 24 bits, a lightweight aluminum alloy handle, and a compact sliding case to hold it all together. Each bit is marked with the "S2" stamp, indicating their high quality and material type. S2 is superior to lower grade steels such as Chromium Vanadium steel (CVS). The bits are magnetically held in the case to prevent them from easily falling out. The tip of the handle that holds the bits has a magnet, snapping the bits in with a satisfying swift motion. Table of Contents 1 DESCRIPTION .................................................................................................................................................................................................. 1 2 DOCUMENT REVISION HISTORY ..................................................................................................................................................................... 2 3 PRODUCT FEATURES ....................................................................................................................................................................................... 2 4 CONTENTS ...................................................................................................................................................................................................... 3 2 DOCUMENT REVISION HISTORY Current document revision is Rev 0. 3 PRODUCT FEATURES The following are notable features:  High quality S2 steel bits. Each bit is individually marked with the "S2" stamp.  Magnetic case and magnetic handle, holding the bits in position.  Lightweight handle, with spinning cap, made from aluminum alloy.  Compact case with sliding lid. Figure 1 shows various physical measurements of the screwdriver set. Figure 1: Specifications. 4 CONTENTS The following items are included:    1pc carrying case 1pc screwdriver handle 24 bits (see Figure 2) o 1pc each Philips Head bit: PH000, PH00, PH0, PH1, PH2 o 1pc each Slotted bit: SL1.5, SL3.0, SL4.0 o 1pc each Torx bit: T2, T3, T4, T5, T6H, T8H, T10H o 1pc each Hex bit: H1.5, H2.0 o 1pc each Tri-Wing bit: Y0.6, Y1.5, Y2.5 o 1pc each Star bit: P2 (star 0.8), P5 (star 1.2) o 1pc Triangle bit 2.3 o 1pc U-shaped bit U2.6 Figure 2: Identification of the 24 bits.
PTS-00134-001 价格&库存
很抱歉,暂时无法提供与“PTS-00134-001”相匹配的价格&库存,您可以联系我们找货
