Proto-Full
1 DESCRIPTION
The PTSolns Proto-Full v2.1 is a prototyping board to
provide the user flexibility in realizing their circuit
design. This full-sized board resembles a traditional
breadboard; in that the breakout section is divided
into rows of five. The board features two different
power input options for conveniently connecting a
battery or a benchtop power supply. Multiple power
rail configurations can be used to support different
voltage levels simultaneously. Silkscreen printing
and component footprints exist on both sides of the
board allowing the user to work on two layers.
Table of Contents
1 DESCRIPTION ......................................................................................................................................................................................... 1
2 DOCUMENT REVISION HISTORY ............................................................................................................................................................. 2
3 PRODUCT FEATURES .............................................................................................................................................................................. 2
3.1 Power Input .................................................................................................................................................................................. 2
3.2 Power Rails ................................................................................................................................................................................... 3
3.3 Ground (GND)............................................................................................................................................................................... 4
3.4 Silkscreen Printing ........................................................................................................................................................................ 4
3.5 Mounting ..................................................................................................................................................................................... 5
3.6 Mark of Authenticity ..................................................................................................................................................................... 5
4 PHYSICAL PROPERTIES ........................................................................................................................................................................... 6
5 ELECTRICAL PROPERTIES ........................................................................................................................................................................ 7
6 USAGE AND APPLICATION ...................................................................................................................................................................... 8
6.1 Power Input .................................................................................................................................................................................. 8
6.2 Jumper Cap Connections ............................................................................................................................................................... 8
6.3 Use of Voltage Regulator on Power Rails ....................................................................................................................................... 9
7 RECOMMENDED ACCESSORIES ............................................................................................................................................................ 10
Current document revision is Rev 0.
3 PRODUCT FEATURES
This section highlights notable features of the Proto-Full v2.1.
3.1 Power Input
The Proto-Full has the following power input options:
1) 2-Pin screw terminal (2.54 mm/0.1 in).
2) Female barrel jack (2.1 mm X 5.5 mm).
These power input options are shown in Figure 1.
Note that the positive terminal of Option 1 is electrically connected to the positive terminal of Option 2. Similarly,
the negative terminal of Option 1 is electrically connected to the negative terminal of Option 2. It is not
recommended to use both power input options simultaneously.
Both power input options can be soldered onto either the front or back of the PCB. For this reason, the footprint of
the female barrel jack of option 2) is unconventional. An additional, electrically isolated, through-hole exists such
that the female barrel jack can be connected on either side while keeping the barrel opening in the same direction
(away from the PCB). An example can be found in Section 6.1
Figure 1: Two power input options for the Proto-Full.
3.2 Power Rails
The Proto-Full features ten rails, each consisting of 30 tie-point through-holes, as shown in Figure 2. The rails can
be electrically connected in different configurations. By default, all rails are initially electrically disconnected. Four
of the rails can be connected to the positive terminal. Similarly, four other rails can be connected to the negative
terminal. The remaining two rails are suggested to be used in one of two ways:
1) Use the provided footprint connection to GND.
2) Use it for a data signal.
Connecting rails is suggested to be done in one of two methods:
1) Using a short wire to bridge the connection and soldering it in place. This is a permanent connection in
which the user does not intent to change the configuration often.
2) Using male header pins connected with 2-Pin jumper caps. This is a temporary connection in which the
user can easily disconnect the rail. This allows the jumper cap to act as an enable/disable for the rail and
allows the rail to be reconfigured to transmit a different signal or voltage. An example can be found in
Section 6.2.
Figure 2: Ten rails of the Proto-Full.
3.3 Ground (GND)
The ground (GND) of the PCB can be electrically connected to an external GND using the GND out pin. By default,
this GND out pin is not connected to any other part of the PCB. Each of the four mounting holes can be connected
to the GND of the PCB separately by closing the corresponding 2-Pin connections (one in each corner of the PCB).
Additionally, the central rail can be connected to the GND of the PCB in a similar fashion.
The ground and negative terminal are by default electrically disconnected. To connect GND to the negative terminal
the corresponding 2-Pin connection (marked as “GND to –“) must be electrically bridged. All GND connection
options are shown in Figure 3. See Figure 8 for the electrical schematic.
Figure 3: Various GND connection options of the Proto-Full. 1) GND out pin, 2) GND of each of the four mounting holes, 3) GND of the
central rail, 4) GND to negative terminal connection.
The breakout section of the Proto-Full is fully labelled along the rows and columns. For ease of use, the silkscreen
printing exists on both sides of the board. White dashed silkscreen lines between tie-points indicate an existing
hardwired electrical connection. All components can be soldered on either side of the board, including
asymmetrical components such as the female barrel jack.
3.5 Mounting
There are four 3.2 mm diameter mounting holes on the PCB as shown in Figure 4. These mounting holes are
intended for hardware such as standoffs, of size M3. Each mounting hole has a 6.4 mm diameter copper pad and
can be connected to the main ground (GND) of the PCB separately by bridging the respective 2-Pin jumper. Figure
7 shows the dimensions of the mounting holes.
Figure 4: Four mounting holes of the Proto-Full.
Authentic PTSolns PCBs have a black solder mask color and are marked with the “PTSolns” logo in white silkscreen
printing. The “Canadian Designed” symbol, consisting of the Canadian Maple Leaf with the word “Designed”
underneath, can also be found on the PCB in white silkscreen printing. The “PTSolns” trademark and the “Canadian
Designed” symbols are shown in Figure 5.
Figure 5: The "Canadian Designed" symbol found on authentic PTSolns PCBs.
The physical properties of the Proto-Full are outlined in Table 1.
Table 1: Physical Properties.
Quantity
Length
Width
Thickness
Corner radius
Weight
Color
Silkscreen
Value
200.7 mm
58.4 mm
1.6 mm
7.6 mm
36 g
Black
White
Reference
Figure 6
Figure 6
Figure 6
Figure 6
Tie-point
Number of tie-points
Tie point spacing
Tie-point hole diameter
Tie-point copper pad diameter
930
2.54 mm/0.1 in
1.0 mm
1.7 mm
Figure 6
Figure 6
Figure 7
Figure 7
Mounting
Hole diameter
Copper pad diameter
Center-to-center distance along
length
Center-to-center distance along width
3.2 mm
6.4 mm
185.4 mm
Figure 7
Figure 7
Figure 6
43.2 mm
Figure 6
PCB
Material
Lead free HASL-RoHS surface finish
FR-4 base
Figure 6: Dimensions of the Proto-Full PCB.
Figure 7: Dimensions of tie-point (left) and mounting hole (right).
The current ratings of the Proto-Full are outlined in Table 2. Electrical connections made by copper traces are shown
in Figure 8. Copper traces have a weight of 1 oz/ft2.
Table 2: Current rating for Proto-Full.
Type of trace
Positive power rails
Negative power rails
Central ground rails
Power input female barrel jack
Power input 2-Pin screw terminal
All GND connections
5-Pin breakout rows
Current rating1
1.5 A
1.5 A
1.5 A
1.5 A
1.5 A
1.5 A
1.0 A
Figure 8: Electrical connections of the Proto-Full.
1
Current ratings based on IPC-2221B and are in part determined assuming a maximum temperature rise of 20 ◦C.
This section presents some usages and applications of the Proto-Full.
6.1 Power Input
This example shows two different options to power the Proto-Full. The image on the left in Figure 9 shows a green
2-Pin screw terminal and a black female barrel jack, both soldered onto the top side of the PCB. The image on the
right in Figure 9 shows the same screw terminal on the top side, however, the female barrel jack is soldered onto
the bottom side of the PCB. In both configurations stand-offs are used to lift the PCB up off the surface.
Figure 9: Power input configuration examples.
Both a screw terminal and a female barrel jack can be soldered into place simultaneously. This gives the user the
ability to power the PCB with different connections, or easily switch between two different sources. Since these
inputs are electrically connected in parallel, care should be taken to not power the PCB via both input methods at
the same time.
Rails and GND connections can be made by simply soldering across the respective 2-Pin gap. This is a permanent
connection. A more temporary connection can be made by soldering male header pins across the 2-Pin gaps and
using 2-Pin jumper caps, as shown in Figure 10.
Figure 10: Connecting rails and GND using 2-Pin jumper caps.
The 2-Pin gap for the various GND connections consists of two through-holes separated by 2.54 mm/0.1 in. Using
the jumper cap method, the male headers required are 1 X 2 Pin with a pitch of 2.54 mm/0.1 in. The gap for the
adjacent positive and negative power rails consists of four through-holes arranged in a 2 X 2 pattern, separated by
2.54 mm/0.1 in. In this situation, a 2 X 2 Pin male header is recommended using the jumper cap method. However,
two 1 X 2 Pin male headers can also be used. Note that when using jumper caps to connect negative to negative
and positive to positive always ensure the jumper caps are not crossed the negative and positive terminal. Mind
the direction the jumper caps are placed in the 2 X 2 configuration.
This example shows an unconventional use of a voltage regulator. The Vin and Vout pins of the voltage regulator
are soldered into the left and right positive voltage rails. This is done at the mid-section of the Proto-Full where the
rails are disconnected by default. The GND pin of the voltage regulator is soldered into the negative voltage rail.
This is done by slightly bending the GND pin backwards to reach the first through-hole of the negative rail. The left
and right negative voltage rails have been bridged to make an electrical connection. Note that two smoothing
capacitors are soldered across the positive and negative rails on either side of the Vin and Vout. This is not always
necessary but recommended. Ratings for smoothing capacitors are project specific.
With this configuration there are two immediate advantages. The first advantage is that two voltage rails are at
different levels. The left is at the supply voltage and the right at a lower down-regulated voltage. This is useful when
working with different voltage levels simultaneously. The other advantage is that this configuration uses minimal
space, as none of the 5-pin breakout rows are used.
Figure 11: Voltage regulator across power rails.
The following is a list of recommended components and accessories to help the user best utilize the Proto-Full.
Female barrel jack. Size: 2.1 mm X 5.5 mm
o Used as one of the power input options for positive and negative connections.
Female header. Pins: 1 X 40 Pin; Pitch: 2.54 mm/0.1 in
o The user can break the full row of pins into smaller sections as required.
Jumper cap. Pins: 2; Pitch: 2.54 mm/0.1 in
o Used to make temporary connection for power rails.
Male header. Pins: 1 X 40 Pin; Pitch: 2.54 mm/0.1 in
Male header. Pins: 2 X 40 Pin; Pitch: 2.54 mm/0.1 in
o The user can break the full row of pins into smaller sections, such as 2 X 2 Pin, which can be used
to connect the positive and negative power rails (with 2-Pin jumper caps)
Screw terminal. Pins: 2; Pitch: 2.54 mm/0.1 in
Stand-off set. Size: M3; Length: various
o Used in mounting holes to secure PCB.
Wire set. A.W.G.: ≥19; Length: various; Type: preformed, DuPont, etc.
o Used in any of the tie-point breakout sections.
很抱歉,暂时无法提供与“PTS-00075-201”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+38.105041+4.94410
- 10+37.9794810+4.92781
