10/100/1000BASE-T SINGLE &
DUAL-PORT TRANSFORMER MODULES
Military / Aerospace Grade
Compliant with IEEE 802.ab for 1000Base-T
350µH OCL with 8mA bias at extended temperatures
Two Operating and Storage Temperature Versions Available:
Standard: -40°C to +85°C
Extended: -55°C to +125°C
IC grade transfer molded package 235°C peak reflow
temperature for non-RoHS versions (MSL 3)
245°C peak reflow temperature for RoHS versions (MSL 4)
Lead finish: Sn63/Pb37 (RoHS compliant version available with
100% pure tin)
Electrical Specifications @ 25°C — Operating Temperature -40°C to +85°C
1000B-5009 3
Insertion
Loss
(dB Min)
0.1-100
Mhz
-1.2
30
Mhz
-18
60
Mhz
-12
80
Mhz
-12
100
Mhz
-10
30
Mhz
-43
60
Mhz
-37
1000B-5012
-1
-18
-12
-12
-10
-43
1000B-5014
-1.4
-16
-12
-12
-10
1000B-5016
-1.2
-18
-12
-12
-10
Part
Number2
100
Mhz
-31
CM to CM
Rejection Ratio
(dB Max)
30
60
100
Mhz
Mhz
Mhz
-30
-25
-18
DM to CM
Rejection Ratio
(dB Max)
30
60
100
Mhz
Mhz
Mhz
-40
-35
-30
-37
-33
-43
-37
-33
-43
-37
-33
1500
-43
-37
-33
-45
-40
-35
-43
-37
-33
1500
-43
-37
-31
-30
-23
-17
-40
-35
-30
1500
Return Loss
(dB Max)
Crosstalk
(dB Max)
Note: 1. Add suffix X for extended temperature version; i.e. 1000B-5001 becomes 1000B-5001X.
2. Add suffix NL for RoHS compliant part; i.e. 1000B-5001 becomes 1000B-5001NL.
Hipot
(Vrms)
1500
3. Not for sale in U.S.
Mechanicals
1000B-5009
Weight . . . . . . . . . . . . . 0.75 grams
Tape and Reel . . . . . . . . . . 250/reel
Tube . . . . . . . . . . . . . . . . . 15/tube
Dimensions: Inches
mm
Unless otherwise specified,
all tolerances are ± .010
0,25
1
pulseelectronics.com
M160.B (6/13)
1000B-5012
.518
13,16
1000B-5012/X
Weight . . . . . . . . . . . . . . 3.5 grams
.735
18,67
.605
15,37
.595
15,11
.760
19,30
.241
6,12
Dimensions: Inches
mm
0,25
1000B-5014
Weight . . . . . . . . . . . . . . 3.0 grams
Tape and Reel . . . . . . . . . . 300/reel
Tube . . . . . . . . . . . . . . . . . 25/tube
1000B-5014/X
.605
15,37
Dimensions: Inches
mm
0,25
2
M160.B (6/13)
1000B-5016
Tape and Reel . . . . . . . . . . 700/reel
Tube . . . . . . . . . . . . . . . . . 30/tube
Dimensions: Inches
mm
0,25
3
M160.B (6/13)
Electrical Schematics
1000B-5009
4
M160.B (6/13)
1000B-5012
5
M160.B (6/13)
1000B-5014
6
M160.B (6/13)
1000B-5016
For More Information
Pulse Worldwide
Headquarters
Two Pearl Buck Court
Bristol, PA 19007
U.S.A.
Pulse Europe
Einsteinstrasse 1
D-71083 Herrenberg
Germany
Tel: 215 781 6400
Fax: 215 781 6403
Tel: 49 7032 7806 0
Fax: 49 7032 7806 135
Pulse China Headquarters
B402, Shenzhen Academy of
Aerospace Technology Bldg.
10th Kejinan Road
High-Tech Zone
Nanshan District
Shenzen, PR China 518057
Tel: 86 755 33966678
Fax: 86 755 33966700
Pulse North China
Room 2704/2705
Super Ocean Finance Ctr.
2067 Yan An Road West
Shanghai 200336
China
Pulse South Asia
135 Joo Seng Road
#03-02
PM Industrial Bldg.
Singapore 368363
Tel: 86 21 62787060
Fax: 86 2162786973
Tel: 65 6287 8998
Fax: 65 6287 8998
Pulse North Asia
3F, No. 198
Zhongyuan Road
Zhongli City
Taoyuan County 320
Taiwan R. O. C.
Tel: 886 3 4356768
Fax: 886 3 4356823 (Pulse)
Fax: 886 3 4356820 (FRE)
Performance warranty of products offered on this data sheet is limited to the parameters specified. Data is subject to change without notice. Other brand and product names mentioned herein may be trademarks
or registered trademarks of their respective owners. © Copyright, 2012. Pulse Electronics, Inc. All rights reserved.
7
M160.B (6/13)
很抱歉,暂时无法提供与“1000B-5012XT”相匹配的价格&库存,您可以联系我们找货
