1000B-5012XNLT
1000B-5012XNLT
    INRCORE
    SMD-24P,15.1x13.2mm
    MDL SGL 1000B 1:1 SMT TU PBC
1000B-5012XNLT 数据手册
10/100/1000BASE-T SINGLE & DUAL-PORT TRANSFORMER MODULES Military / Aerospace Grade Compliant with IEEE 802.ab for 1000Base-T 350µH OCL with 8mA bias at extended temperatures Two Operating and Storage Temperature Versions Available: Standard: -40°C to +85°C Extended: -55°C to +125°C IC grade transfer molded package 235°C peak reflow temperature for non-RoHS versions (MSL 3) 245°C peak reflow temperature for RoHS versions (MSL 4) Lead finish: Sn63/Pb37 (RoHS compliant version available with 100% pure tin) Electrical Specifications @ 25°C — Operating Temperature -40°C to +85°C 1000B-5009 3 Insertion Loss (dB Min) 0.1-100 Mhz -1.2 30 Mhz -18 60 Mhz -12 80 Mhz -12 100 Mhz -10 30 Mhz -43 60 Mhz -37 1000B-5012 -1 -18 -12 -12 -10 -43 1000B-5014 -1.4 -16 -12 -12 -10 1000B-5016 -1.2 -18 -12 -12 -10 Part Number2 100 Mhz -31 CM to CM Rejection Ratio (dB Max) 30 60 100 Mhz Mhz Mhz -30 -25 -18 DM to CM Rejection Ratio (dB Max) 30 60 100 Mhz Mhz Mhz -40 -35 -30 -37 -33 -43 -37 -33 -43 -37 -33 1500 -43 -37 -33 -45 -40 -35 -43 -37 -33 1500 -43 -37 -31 -30 -23 -17 -40 -35 -30 1500 Return Loss (dB Max) Crosstalk (dB Max) Note: 1. Add suffix X for extended temperature version; i.e. 1000B-5001 becomes 1000B-5001X. 2. Add suffix NL for RoHS compliant part; i.e. 1000B-5001 becomes 1000B-5001NL. Hipot (Vrms) 1500 3. Not for sale in U.S. Mechanicals 1000B-5009 Weight . . . . . . . . . . . . . 0.75 grams Tape and Reel . . . . . . . . . . 250/reel Tube . . . . . . . . . . . . . . . . . 15/tube Dimensions: Inches mm Unless otherwise specified, all tolerances are ± .010 0,25 1 pulseelectronics.com M160.B (6/13) 10/100/1000BASE-T SINGLE & DUAL-PORT TRANSFORMER MODULES Military / Aerospace Grade 1000B-5012 .518 13,16 1000B-5012/X Weight . . . . . . . . . . . . . . 3.5 grams Tape and Reel . . . . . . . . . . 250/reel Tube . . . . . . . . . . . . . . . . . 15/tube .735 18,67 .605 15,37 .595 15,11 .760 19,30 .241 6,12 Dimensions: Inches mm Unless otherwise specified, all tolerances are ± .010 0,25 1000B-5014 Weight . . . . . . . . . . . . . . 3.0 grams Tape and Reel . . . . . . . . . . 300/reel Tube . . . . . . . . . . . . . . . . . 25/tube 1000B-5014/X .605 15,37 Dimensions: Inches mm Unless otherwise specified, all tolerances are ± .010 0,25 2 pulseelectronics.com M160.B (6/13) 10/100/1000BASE-T SINGLE & DUAL-PORT TRANSFORMER MODULES Military / Aerospace Grade 1000B-5016 Weight . . . . . . . . . . . . . 0.75 grams Tape and Reel . . . . . . . . . . 700/reel Tube . . . . . . . . . . . . . . . . . 30/tube Dimensions: Inches mm Unless otherwise specified, all tolerances are ± .010 0,25 3 pulseelectronics.com M160.B (6/13) 10/100/1000BASE-T SINGLE & DUAL-PORT TRANSFORMER MODULES Military / Aerospace Grade Electrical Schematics 1000B-5009 4 pulseelectronics.com M160.B (6/13) 10/100/1000BASE-T SINGLE & DUAL-PORT TRANSFORMER MODULES Military / Aerospace Grade 1000B-5012 5 pulseelectronics.com M160.B (6/13) 10/100/1000BASE-T SINGLE & DUAL-PORT TRANSFORMER MODULES Military / Aerospace Grade 1000B-5014 6 pulseelectronics.com M160.B (6/13) 10/100/1000BASE-T SINGLE & DUAL-PORT TRANSFORMER MODULES Military / Aerospace Grade 1000B-5016 For More Information Pulse Worldwide Headquarters Two Pearl Buck Court Bristol, PA 19007 U.S.A. Pulse Europe Einsteinstrasse 1 D-71083 Herrenberg Germany Tel: 215 781 6400 Fax: 215 781 6403 Tel: 49 7032 7806 0 Fax: 49 7032 7806 135 Pulse China Headquarters B402, Shenzhen Academy of Aerospace Technology Bldg. 10th Kejinan Road High-Tech Zone Nanshan District Shenzen, PR China 518057 Tel: 86 755 33966678 Fax: 86 755 33966700 Pulse North China Room 2704/2705 Super Ocean Finance Ctr. 2067 Yan An Road West Shanghai 200336 China Pulse South Asia 135 Joo Seng Road #03-02 PM Industrial Bldg. Singapore 368363 Tel: 86 21 62787060 Fax: 86 2162786973 Tel: 65 6287 8998 Fax: 65 6287 8998 Pulse North Asia 3F, No. 198 Zhongyuan Road Zhongli City Taoyuan County 320 Taiwan R. O. C. Tel: 886 3 4356768 Fax: 886 3 4356823 (Pulse) Fax: 886 3 4356820 (FRE) Performance warranty of products offered on this data sheet is limited to the parameters specified. Data is subject to change without notice. Other brand and product names mentioned herein may be trademarks or registered trademarks of their respective owners. © Copyright, 2012. Pulse Electronics, Inc. All rights reserved. 7 pulseelectronics.com M160.B (6/13)
1000B-5012XNLT 价格&库存
很抱歉,暂时无法提供与“1000B-5012XNLT”相匹配的价格&库存,您可以联系我们找货
