IP67 CASE FOR PYSENSE/PYTRACK
    PYCOM
    塑料 - 未指定 黑色 手持,包含盖 2.953" 长 x 2.953" 宽(75.00mm x 75.00mm) X 1.378"(35.00mm)
IP67 CASE FOR PYSENSE/PYTRACK 数据手册
      IP67 Case for Pysense/Pytrack Description This is the IP67 case for Pysense and Pytrack. Space available for Pycom module (whether you are using a WiPy 2.0, LoPy, SiPy, GPy or FiPy), Pycom shield (Pysense or Pytrack) and a LiPo battery. Waterproofing by using silicone gasket. UV resistant case. Mountable onto external surface/brackets by opening the blind lids. Dimensions External case dimensions: W 75 x D 75 x H 35 mm. Internal available space: W 67 x 46 x H 25.4 mm. Additional information   Weight 0.100 kg Dimensions 7.5 x 7.5 x 3.5 cm mm. Internal available space: W 67 x 46 x H 25.4 mm.                                                              https://pycom.io/product/ip67‐case/ 8‐1‐18
IP67 CASE FOR PYSENSE/PYTRACK 价格&库存
很抱歉,暂时无法提供与“IP67 CASE FOR PYSENSE/PYTRACK”相匹配的价格&库存,您可以联系我们找货
