BG95M3LA-MINIPCIE
BG95M3LA-MINIPCIE
    QUECTEL(移远)
    手机,导航 BeiDou,EGDE,Galileo,GLONASS,GPS,GNSS,GSM,LTE RF 收发器模块 850MHz,900MHz,1.8GHz,1.9GHz 不含天线 表面贴装型
BG95M3LA-MINIPCIE 数据手册
23.6 mm Quectel BG95 Series LTE Cat M1/ Cat NB2/ EGPRS Module 19.9 mm 2.2 mm BG95 is a series of multi-mode LPWA modules supporting LTE Cat M1/Cat NB2/EGPRS and integrated GNSS.It is 3GPP Rel-14 compliant and offers maximum data rates of 588 kbps downlink and 1119 kbps uplink under LTE Cat M1. It features ultra-low power consumption by leveraging the integrated RAM/flash as well as the ARM Cortex A7 processor supporting ThreadX, achieving up to 70% reduction in PSM leakage and 85% reduction in eDRX current consumption compared to its predecessor. BG95 boasts a comprehensive set of hardware-based security features and enables trusted applications to run directly on the Cortex A7 TrustZone engine. Additionally, BG95 provides pin-to-pin compatibility with Quectel LTE Cat 4 modules EG91/EG95, LTE Cat M1/Cat NB1/EGPRS module BG96, NB-IoT module BC95, UMTS/HSPA modules UG95/UG96 and GSM/GPRS module M95. With a cost-effective SMT form factor of 23.6 mm × 19.9 mm × 2.2 mm and high integration level, BG95 enables integrators and developers to easily design their applications and take advantage from the module’s low power consumption and mechanical intensity. Its advanced LGA package allows fully automated manufacturing for high-volume applications. A rich set of Internet protocols, industry-standard interfaces and abundant functions extend the applicability of the module to a wide range of M2M applications such as wireless POS, smart metering, tracking, wearable devices, etc. Key Features LTE Cat M1/Cat NB2/EGPRS module with ultra-low power consumption Easy migration from Quectel GSM/GPRS, UMTS/HSPA and LTE modules Integrated RAM and flash in the baseband chipset LTE Cat M1 & Cat NB2 EGPRS LGA Package DFOTA USB 2.0 Interface Quectel Enhanced AT Commands Integrated RAM/ Flash in Chipset Comprehensive set of hardware-based security features Support VoLTE* (Cat M1 only), CS voice* for GSM, QuecOpen ®, eSIM, etc. Fast time-to-market: reference designs, evaluation tools and timely technical support minimize design-in time and development efforts Embedded Abundant Protocols Compact SMT form factor ideal for size-constrained applications with tight space Robust mounting and interfaces Ultra-low Power Consumption Rev.: V1.5 | Status: Released EMAIL US: info@quectel.com VISIT US: www.quectel.com Quectel BG95 Series LPWA Module BG95-M1 BG95-M2 BG95-M3 BG95-N1 BG95-M4 BG95-M5 BG95-M6 BG95-MF Region/Operator For the Global For the Global For the Global For the Global For the Global For the Global For the Global For the Global Dimensions (mm) 23.6 × 19.9 × 2.2 23.6 × 19.9 × 2.2 23.6 × 19.9 × 2.2 23.6 × 19.9 × 2.2 23.6 × 19.9 × 2.2 23.6 × 19.9 × 2.2 23.6 × 19.9 × 2.2 23.6 × 19.9 × 2.2 Operating Temperature -35 °C to +75 °C -35 °C to +75 °C -35 °C to +75 °C -35 °C to +75 °C -35 °C to +75 °C -35 °C to +75 °C -35 °C to +75 °C -35 °C to +75 °C Extended Temperature -40 °C to +85 °C -40 °C to +85 °C -40 °C to +85 °C -40 °C to +85 °C -40 °C to +85 °C -40 °C to +85 °C -40 °C to +85 °C -40 °C to +85 °C Cat M1 Only: B1/B2/B3/B4/B5/B8/ B12/B13/B18/B19/ B20/B25/B26/B27/ B28/B66/B85 Cat M1: B1/B2/B3/B4/B5/B8/ B12/B13/B18/B19/ B20/B25/B26/B27/ B28/B66/B85 Cat M1: B1/B2/B3/B4/B5/B8/ B12/B13/B18/B19/ B20/B25/B26/B27/ B28/B66/B85 Cat M1: B1/B2/B3/B4/B5/B8/ B12/B13/B18/B19/ B20/B25/B26/B27/ B28/B66/B85 Cat M1: B1/B2/B3/B4/B5/B8/ B12/B13/B18/B19/ B20/B25/B26/B27/ B28/B66/B85 Cat M1: B1/B2/B3/B4/B5/B8/ B12/B13/B18/B19/ B20/B25/B26/B27/ B28/B66/B85 Cat NB2: B1/B2/B3/B4/B5/B8/ B12/B13/B18/B19/ B20/B25/B28/B66/ B71/B85 Cat NB2: B1/B2/B3/B4/B5/B8/ B12/B13/B18/B19/ B20/B25/B28/B66/ B71/B85 Cat NB2 Only: B1/B2/B3/B4/B5/B8/ B12/B13/B18/B19/ B20/B25/B28/B66/ B71/B85 Cat M1: B1/B2/B3/B4/B5/B8/ B12/B13/B18/B19/ B20/B25/B26/B27/ B28/B31① /B66/ B72①/B73① /B85 Cat NB2: B1/B2/B3/B4/B5/B8/ B12/B13/B18/B19/ B20/B25/B28/B31①/ B66/B72① /B73①/ B85 Cat NB2: B1/B2/B3/B4/B5/B8/ B12/B13/B18/B19/ B20/B25/B28/B66/ B71/B85 Cat NB2: B1/B2/B3/B4/B5/B8/ B12/B13/B18/B19/ B20/B25/B28/B66/ B71/B85 Cat NB2: B1/B2/B3/B4/B5/B8/ B12/B13/B18/B19/ B20/B25/B28/B66/ B71/B85 Temperature Range Frequency Bands LTE-FDD GSM/EDGE / / 850/900/ 1800/1900 MHz / / 850/900/ 1800/1900 MHz / / GNSS GPS/GLONASS/ BeiDou/Galileo/QZSS GPS/GLONASS/ BeiDou/Galileo/QZSS GPS/GLONASS/ BeiDou/Galileo/QZSS GPS/GLONASS/ BeiDou/Galileo/QZSS GPS/GLONASS/ BeiDou/Galileo/QZSS GPS/GLONASS/ BeiDou/Galileo/QZSS GPS/GLONASS/ BeiDou/Galileo/QZSS GPS/GLONASS/ BeiDou/Galileo/QZSS Wi-Fi (For Positioning) / / / / / / / 2.4 GHz Cat M1: Max. 588 (DL) Max. 1119 (UL) Cat M1: Max. 588 (DL) Max. 1119 (UL) Cat M1: Max. 588 (DL) Max. 1119 (UL) / Cat M1: Max. 588 (DL) Max. 1119 (UL) Cat M1: Max. 588 (DL) Max. 1119 (UL) Cat M1: Max. 588 (DL) Max. 1119 (UL) Cat M1: Max. 588 (DL) Max. 1119 (UL) NB-IoT Data Rate (kbps) / Cat NB2: Max. 127 (DL) Max. 158.5 (UL) Cat NB1: Max. 32 (DL) Max. 70 (UL) Cat NB2: Max. 127 (DL) Max. 158.5 (UL) Cat NB1: Max. 32 (DL) Max. 70 (UL) Cat NB2: Max. 127 (DL) Max. 158.5 (UL) Cat NB1: Max. 32 (DL) Max. 70 (UL) Cat NB2: Max. 127 (DL) Max. 158.5 (UL) Cat NB1: Max. 32 (DL) Max. 70 (UL) Cat NB2: Max. 127 (DL) Max. 158.5 (UL) Cat NB1: Max. 32 (DL) Max. 70 (UL) Cat NB2: Max. 127 (DL) Max. 158.5 (UL) Cat NB1: Max. 32 (DL) Max. 70 (UL) Cat NB2: Max. 127 (DL) Max. 158.5 (UL) Cat NB1: Max. 32 (DL) Max. 70 (UL) EDGE Data Rate (kbps) / / Max. 296 (DL) Max. 236.8 (UL) / / Max. 296 (DL) Max. 236.8 (UL) / / GPRS Data Rate (kbps) / / Max. 107 (DL) Max. 85.6 (UL) / / Max. 107 (DL) Max. 85.6 (UL) / / (U)SIM × 1 (1.8 V only) × 1 (1.8 V only) × 1 (1.8 V only) × 1 (1.8 V only) × 1 (1.8 V only) × 1 (1.8 V only) × 1 (1.8 V only) × 1 (1.8 V only) UART ×3 ×3 ×3 ×3 ×3 ×3 ×3 ×3 USB 2.0 ×1 ×1 ×1 ×1 ×1 ×1 ×1 ×1 PCM* × 1 (for VoLTE Only) × 1 (for VoLTE Only) × 1 (for VoLTE Only) / × 1 (for VoLTE Only) × 1 (for VoLTE Only) × 1 (for VoLTE Only) × 1 (for VoLTE Only) I2C* × 1 (for VoLTE Only) × 1 (for VoLTE Only) × 1 (for VoLTE Only) / × 1 (for VoLTE Only) × 1 (for VoLTE Only) × 1 (for VoLTE Only) × 1 (for VoLTE Only) Antenna ×2 ×2 ×2 ×2 ×2 ×2 ×2 ×3 GPIO ×9 ×9 ×9 ×9 ×9 ×9 ×9 × 7* GRFC ×2 ×2 ×2 × 2* / × 2* × 2* × 2* VoLTE* for Cat M1 VoLTE* for Cat M1 VoLTE for Cat M1 CS Voice for GSM / VoLTE* for Cat M1 VoLTE* for Cat M1 CS Voice* for GSM VoLTE* for Cat M1 VoLTE* for Cat M1 Point-to-point MO/ MT SMS Cell Broadcast Text and PDU Mode Point-to-point MO/ MT SMS Cell Broadcast Text and PDU Mode Point-to-point MO/ MT SMS Cell Broadcast Text and PDU Mode Point-to-point MO/ MT SMS Cell Broadcast Text and PDU Mode Point-to-point MO/ MT SMS Cell Broadcast Text and PDU Mode Point-to-point MO/ MT SMS Cell Broadcast Text and PDU Mode Point-to-point MO/ MT SMS Cell Broadcast Text and PDU Mode Point-to-point MO/ MT SMS Cell Broadcast Text and PDU Mode DFOTA ● ● ● ● ● ● ● ● * * ● QuecOpen® * ● ● * * QuecLocator® Cell ID Positioning* Cell ID Positioning* Cell ID Positioning Cell ID Positioning* Cell ID Positioning* Cell ID Positioning* Cell ID Positioning* Cell ID Positioning* Wi-Fi Positioning* SoftSIM * * ● * * * * * IoT Platform Access / / AWS/ Azure / / / / / Data Transmission LTE-M Data Rate (kbps) Interfaces Voice Voice SMS SMS Enhanced Features Notes: 1. ① LTE-FDD B31/B72/B73 for BG95-M4 supports Power Class 2* and Power Class 3. 2. ● means supported. 3. * means under development/on-going/planning. Copyright © 2020 Quectel Wireless Solutions Co., Ltd. All Rights Reserved http://www.quectel.com HQ address: Building 5, Shanghai Business Park Phase III (Area B), No.1016 Tianlin Road, Minhang District, Shanghai, China 200233 Tel: +86 21 51086236 Email: info@quectel.com Quectel BG95 Series LPWA Module BG95-M1 BG95-M2 BG95-M3 BG95-N1 BG95-M4 BG95-M5 BG95-M6 BG95-MF Protocols PPP/TCP/UDP/SSL/ TLS/FTP(S)/HTTP(S)/ NITZ/PING/MQTT/ LwM2M/CoAP/IPv6 PPP/TCP/UDP/SSL/ TLS/FTP(S)/HTTP(S)/ NITZ/PING/MQTT/ LwM2M/CoAP/IPv6 PPP/TCP/UDP/SSL/ TLS/FTP(S)/HTTP(S)/ NITZ/PING/MQTT/ LwM2M/CoAP/IPv6 PPP/TCP/UDP/SSL/ TLS/FTP(S)/HTTP(S)/ NITZ/PING/MQTT/ LwM2M/CoAP*/IPv6* PPP/TCP/UDP/SSL/TLS/ FTP(S)/HTTP(S)/NITZ/ PING/MQTT/LwM2M/ CoAP/IPv6 PPP/TCP/UDP/SSL/ TLS/FTP(S)/HTTP(S)/ NITZ/PING/MQTT/ LwM2M/CoAP/IPv6 PPP/TCP/UDP/SSL/ TLS/FTP(S)/HTTP(S)/ NITZ/PING/MQTT/ LwM2M/CoAP/IPv6 PPP/TCP/UDP/SSL/ TLS/FTP(S)/HTTP(S)/ NITZ/PING/MQTT/ LwM2M/CoAP/IPv6 USB Serial Driver Windows 7/8/8.1/10, Linux 2.6–5.4*, Android 4.x–10.x* Windows 7/8/8.1/10, Linux 2.6–5.4*, Android 4.x–10.x* Windows 7/8/8.1/10, Linux 2.6–5.4*, Android 4.x–10.x* Windows 7/8/8.1/10, Linux 2.6–5.4*, Android 4.x–10.x* Windows 7/8/8.1/10, Linux 2.6–5.4*, Android 4.x–10.x* Windows 7/8/8.1/10, Linux 2.6–5.4*, Android 4.x–10.x* Windows 7/8/8.1/10, Linux 2.6–5.4*, Android 4.x–10.x* Windows 7/8/8.1/10, Linux 2.6–5.4*, Android 4.x–10.x* GNSS/RIL Driver Android 4.x–10.x* Android 4.x–10.x* Android 4.x–10.x* Android 4.x–10.x* Android 4.x–10.x* Android 4.x–10.x* Android 4.x–10.x* Android 4.x–10.x* America: Verizon/AT&T/Sprint Europe: Vodafone*/ Deutsche Telekom*/ Telefónica* America: Verizon/AT&T/ Sprint/T-Mobile* Canada: Rogers*/Telus* China: China Telecom*/ China Mobile*/ China Unicom* Europe: Vodafone*/ Deutsche Telekom*/ Telefónica* America: Verizon/ AT&T/ Sprint/T-Mobile* Canada: Rogers*/Telus* China: China Telecom*/ China Mobile*/ China Unicom* TBD / Europe: Vodafone*/ Deutsche Telekom* America: Verizon*/AT&T*/ T-Mobile*/Sprint* China: China Telecom*/ China Mobile*/ China Unicom* South Korea: SKT*/LGU+* Japan: NTT DOCOMO*/ SoftBank*/KDDI* Australia: Telstra* Europe: Vodafone*/ Deutsche Telekom* America: Verizon*/AT&T*/ T-Mobile*/Sprint* China: China Telecom*/ China Mobile*/ China Unicom* South Korea: SKT*/LGU+* Japan: NTT DOCOMO*/ SoftBank*/KDDI* Australia: Telstra* / Global: GCF Europe: CE North America: PTCRB America: FCC Canada: IC Brazil: Anatel Mexico: IFETEL* China: SRRC*/NAL*/CCC* South Korea: KC* Taiwan China: NCC* Japan: JATE*/TELEC* Australia/New Zealand: RCM Thailand: NBTC* Singapore: IMDA* Global: GCF Europe: CE North America: PTCRB America: FCC Canada: IC Brazil: Anatel Mexico: IFETEL* China: SRRC*/NAL*/CCC* South Korea: KC* Taiwan China: NCC* Japan: JATE*/TELEC* Australia/New Zealand: RCM Thailand: NBTC* Singapore: IMDA* TBD Europe: CE* Brazil: Anatel* Global: GCF* Europe: CE* North America: PTCRB* America: FCC* Canada: IC* China: SRRC*/NAL*/CCC* South Korea: KC* Taiwan China: NCC* Japan: JATE*/TELEC* Australia/New Zealand: RCM* Thailand: NBTC* Singapore: IMDA* Global: GCF* Europe: CE* North America: PTCRB* America: FCC* Canada: IC* China: SRRC*/NAL*/CCC* South Korea: KC* Taiwan China: NCC* Japan: JATE*/TELEC* Australia/New Zealand: RCM* Thailand: NBTC* Singapore: IMDA* Global: GCF* Europe: CE* North America: PTCRB* America: FCC* Canada: IC* Australia/New Zealand: RCM* Regulatory Global: GCF Europe: CE North America: PTCRB America: FCC Canada: IC Japan: JATE*/TELEC* Australia/New Zealand: RCM Others RoHS RoHS/ATEX* RoHS/PEN/ATEX* RoHS RoHS RoHS RoHS RoHS 2.6–4.8, typ. 3.3 2.6–4.8, typ. 3.3 3.3–4.3, typ. 3.8 2.6–4.8, typ. 3.3 3.2–4.2, typ. 3.8 3.3–4.3, typ. 3.8 3.3–4.3, typ. 3.8 Typ. 3.8 Power Class 3 23 @ LTE Bands Power Class 3 23 @ LTE Bands Power Class5 21 @ LTE Bands Software Features Certifications Carrier Electrical Features Supply Voltage ② (V) Max Output Power (dBm) Power Class 5 21 @ LTE Bands Power Class 5 21 @ LTE Bands Power Class 5 21 @ LTE Bands Power Class 5 21 @ LTE Bands Power Class 2* 26 @ B31/B72/B73 Power Class 3 23 @ B31/B72/B73 Power Class 5 21 @ other LTE Bands Power Consumption @ PSM (μA) 4 3.9 3.9 4 4 6 5 TBD Sleep Mode: 1.7 @ DRX = 1.28 s 0.549 @ e-I-DRX = 81.92 s Idle Mode: 21.2 @ DRX = 1.28 s 20.6 @ e-I-DRX = 81.92 s Active Mode: 219 @ 21 dBm, GNSS off Sleep Mode: 1.65 @ DRX = 1.28 s 0.63 @ e-IDRX = 81.92 s Idle Mode: 18.9 @ DRX = 1.28 s 18.2 @ e-I-DRX = 81.92 s Active Mode: 199 @ 21 dBm, GNSS off Sleep Mode: 1.7 @ DRX = 1.28 s 0.554 @ e-IDRX = 81.92 s Idle Mode: 18.2 @ DRX = 1.28 s 17.7 @ e-I-DRX = 81.92 s Active Mode: 198 @ 21 dBm, GNSS off 241 @ 26 dBm, GNSS off Sleep Mode: 1.7 @ DRX = 1.28 s 0.72 @ e-IDRX = 81.92 s Idle Mode: 17.3 @ DRX = 1.28 s 16.6 @ e-I-DRX = 81.92 s Active Mode: 228 @ 23 dBm, GNSS off Sleep Mode: 1.5 @ DRX = 1.28 s 0.58 @ e-IDRX = 81.92 s Idle Mode: 18.5 @ DRX = 1.28 s 18.2 @ e-I-DRX = 81.92 s Active Mode: 231@ 23 dBm, GNSS off TBD Power Consumption @ LTE Cat M1 (mA) Sleep Mode: 1.7 @ DRX = 1.28 s 0.577 @ e-I-DRX = 81.92 s Idle Mode: 20 @ DRX = 1.28 s 19.57 @ e-I-DRX = 81.92 s Active Mode: 217 @ 21 dBm, GNSS off Sleep Mode: 1.56 @ DRX = 1.28 s 0.67 @ e-IDRX = 81.92 s Idle Mode: 14.8 @ DRX = 1.28 s 14.3 @ e-I-DRX = 81.92 s Active Mode: 172 @ 21 dBm, GNSS off Sleep Mode: 1.4 @ DRX = 1.28 s 0.592 @ e-IDRX = 81.92 s Idle Mode: 14.6 @ DRX = 1.28 s 14.1 @ e-I-DRX = 81.92 s Active Mode: 163 @ 21 dBm, GNSS off 213 @ 26 dBm, GNSS off Sleep Mode: 1.67 @ DRX = 1.28 s 0.68 @ e-IDRX = 81.92 s Idle Mode: 13.5 @ DRX = 1.28 s 13.1 @ e-I-DRX = 81.92 s Active Mode: 208 @ 23 dBm, GNSS off Sleep Mode: 1.41 @ DRX = 1.28 s 0.55 @ e-IDRX = 81.92 s Idle Mode: 14.2 @ DRX = 1.28 s 14 @ e-I-DRX = 81.92 s Active Mode: 194 @ 23 dBm, GNSS off TBD / Sleep Mode: 1.6 @ DRX = 1.28 s 0.592 @ e-IDRX = 81.92 s Idle Mode: 16.8 @ DRX = 1.28 s 16.4 @ e-I-DRX = 81.92 s Active Mode: 177 @ 21 dBm, GNSS off Power Consumption @ LTE Cat NB1 (mA) Sleep Mode: 1.7 @ DRX = 1.28 s 0.577 @ e-I-DRX = 81.92 s Idle Mode: 20 @ DRX = 1.28 s 19.57 @ e-I-DRX = 81.92 s Active Mode: 217 @ 21 dBm, GNSS off Notes: 1. ① LTE-FDD B31/B72/B73 for BG95-M4 supports Power Class 2* and Power Class 3. 2. ② please refer to the hardware design manual for more specific requirements on the power supply voltage. 3. * means under development/on-going/planning. 4. ● means supported. Copyright © 2020 Quectel Wireless Solutions Co., Ltd. All Rights Reserved http://www.quectel.com HQ address: Building 5, Shanghai Business Park Phase III (Area B), No.1016 Tianlin Road, Minhang District, Shanghai, China 200233 Tel: +86 21 51086236 Email: info@quectel.com
BG95M3LA-MINIPCIE 价格&库存
很抱歉,暂时无法提供与“BG95M3LA-MINIPCIE”相匹配的价格&库存,您可以联系我们找货
