EM06JLA-512-SGAD
EM06JLA-512-SGAD
    QUECTEL(移远)
    手机,导航 BeiDou,Galileo,GLONASS,GPS,GNSS,HSPA+,LTE,UMTS,WCDMA RF 收发器模块 不含天线 卡边
EM06JLA-512-SGAD 数据手册
Build a Smarter World Quectel EM06 IoT/M2M-optimized LTE-A Cat 6 M.2 Module Quectel EM06 is a series of LTE Advanced category 6 module optimized specially for M2M and IoT applications. Adopting the 3GPP Rel. 11 LTE technology, it delivers M2M-optimized speeds of 300Mbps downlink and 50Mbps uplink peak data rates. Designed in the M.2 form factor, EM06 contains 4 variants (EM06-E, EM06-J, EM06-A and EM06-LA①) for different target regions and these variants nearly cover all the main stream carriers worldwide. EM06 supports Qualcomm® IZat™ location technology Gen8C Lite (GPS, GLONASS, BeiDou, Galileo and QZSS). The integrated GNSS greatly simplifies product design, and provides quicker, more accurate and more dependable positioning capability. A rich set of Internet protocols, industry-standard interfaces and abundant functionalities (USB drivers for Windows 7/ 8/8.1/10, Linux, Android) extend the applicability of the module to a wide range of M2M and IoT applications such as industrial router, home gateway, set top box, industrial laptop, consumer laptop, industrial PDA, rugged tablet PC, video surveillance and digital signage, etc. Key Benefits LTE-A Cat 6 module with M.2 form factor, optimized for M2M and IoT applications LTE Cat 6 Max 300Mbps (DL) Max 50Mbps (UL) Max 42Mbps (DL) Max 5.76Mbps (UL) M.2 Form Factor Embedded Abundant Protocols eSIM Multi-constellation GNSS USB 2.0 High Speed Interface USB Drivers Quectel Enhanced AT Commands Supports LTE-A carrier aggregation Worldwide LTE-A and UMTS/HSPA+ coverage Multi-constellation GNSS receiver available for applications requiring fast and accurate fixes in any environment Feature refinements: supports DFOTA and DTMF MIMO technology meets demands for data rate and link reliability in modem wireless communication systems Rev.: V1.5| Status: Released EMAIL US: info@quectel.com VISIT US: www.quectel.com 42.0mm Quectel EM06 IoT/M2M-optimized LTE-A Cat 6 M.2 Module 30.0mm Variant for EMEA/APAC②/Brazil EM06-E LTE-FDD: B1/B3/B5/B7/B8/B20/B28/B32③ LTE-TDD: B38/B40/B41 2×CA: B1+B1/B5/B8/B20/B28; B3+B3/B5/B7/B8/B20/B28; B7+B5/B7/B8/B20/B28; B20+B32③; B38+B38; B40+B40; B41+B41 WCDMA: B1/B3/B5/B8 Variant for Japan EM06-J LTE-FDD: B1/B3/B8/B18/B19/B26/B28 LTE-TDD: B41 2×CA: B1+B1/B8/B18/B19/B26/B28; B3+B3/B8/B18/B19/B26/B28; B41+B41 WCDMA: B1/B3/B6/B8/B19 Variant for North America EM06-A LTE-FDD: B2/B4/B5/B7/B12/B13/B25/B26/B29③/ B30/B66 LTE-TDD: B41 2×CA: B2+B2/B5/B12/B13/B29③; B4+B4/B5/B12/B13/B29③; B7+B5/B7/B12/B26; B25+B5/B12/B25/B26; B30+B5/B12/B29③; B66+B5/B12/B13/B29③/B66; B41+B41 WCDMA: B2/B4/B5 Variant for Latin America EM06-LA (Under Planning) LTE-FDD: B2/B3/B4/B5/B7/B8/B20/B28 2×CA: B2+B2/B5/B8/B20/B28; B3+B3/B5/B7/B8/B20/B28; B4+B4/B5/B8/B20/B28; B7+B5/B7/B8/B20/B28 WCDMA: B2/B3/B4/B5/B8 Data LTE: LTE-FDD: Max 300Mbps (DL)/Max 50Mbps (UL) LTE-TDD: Max 226Mbps (DL)/Max 28Mbps (UL) UMTS: DC-HSDPA: Max 42Mbps (DL) HSUPA: Max 5.76Mbps (UL) WCDMA: Max 384Kbps (DL)/Max 384Kbps (UL) SMS Point-to-point MO and MT SMS Cell Broadcast Text and PDU Mode Interfaces USB 2.0, Supports Slave Mode Digital Audio Through PCM Interface I2C × 1 (U)SIM Interface × 2: 1.8V/3.0V ANTCTL* × 4 W_DISABLE1#: Control Airplane Mode RESET#: Reset the Module WAKE_ON_WAN#: Wake up the Host WWAN_LED#: Indicate Network Status Main, Diversity and GNSS Antenna Interfaces Enhanced Features MIMO: 2 × 2, 4 × 2, DL Digital Audio and VoLTE (Voice over LTE) (Optional) (U)SIM Card Detection DTMF: Dual-tone Multi-frequency Support Dual SIM Single Standby* DFOTA: Delta Firmware over the Air GNSS: GPS/GLONASS/BeiDou/Galileo/QZSS Electrical Characteristics Output Power: Class 3 (23dBm±2dB) for LTE-FDD Class 3 (23dBm±2dB) for LTE-TDD Class 3 (24dBm+1/-3dB) for WCDMA Consumption: 50uA @Power off 4.36mA @Sleep, Typ. 22.3mA @Idle Software Features Support eSIM MBIM Driver: Windows 10 USB Serial Driver: Windows 7/8/8.1/10, Linux 2.6/3.x/4.1~4.15, Android 4.x/5.x/6.x/7.x/8.x/9.x RIL Driver: Android 4.x/5.x/6.x/7.x/8.x/9.x NDIS Driver: Windows 7/8/8.1/10 Copyright © 2019 Quectel Wireless Solutions Co., Ltd. All Rights Reserved http://www.quectel.com HQ address: 7th Floor, Hongye Building, No.1801 Hongmei Road, Xuhui District, Shanghai 200233, China Tel: +86 21 51086236 Email: info@quectel.com 2.3mm ECM Driver*: Linux 2.6/3.x/4.1~4.15 Gobinet Driver: Linux 2.6/3.x/4.1~4.15 QMI_WWAN Driver: Linux 3.x (3.4 or later)/4.1~4.15 Protocols: PPP/QMI/TCP*/UDP*/FTP*/HTTP*/NTP*/PING*/ HTTPS*/SMTP*/MMS*/FTPS*/SMTPS*/SSL* General Features 3GPP E-UTRA Release 11 Bandwidth: 1.4/3/5/10/15/20/40 (2×CA)MHz Supply Voltage: 3.135V~4.4V, 3.7V Typ. Temperature Range: -40°C ~ +85°C Dimensions: 42.0mm × 30.0mm × 2.3mm M.2 Package Approx. 6.0g 3GPP TS27.007 and Quectel Enhanced AT Commands Approvals Carrier: Deutsche Telekom* (Europe) Verizon*/AT&T*/Sprint* (North America) KDDI (Japan) Telstra (Australia) Regulatory: GCF (Global) CE (Europe) FCC/PTCRB (North America) IC (Canada) NCC (Taiwan) JATE/TELEC (Japan) RCM (Australia/New Zealand) ICASA* (South Africa) Others: RoHS Compliant WHQL ① Under Planning. ② APAC excludes Japan and CMCC. ③ LTE-FDD B29 and B32 support Rx only, and in 2×CA they are only for secondary component carrier. * Under Development.
EM06JLA-512-SGAD 价格&库存
很抱歉,暂时无法提供与“EM06JLA-512-SGAD”相匹配的价格&库存,您可以联系我们找货
EM06JLA-512-SGAD
  • 1+1032.733341+133.59983
  • 10+909.5102010+117.65903
  • 25+866.9187725+112.14918
  • 100+808.61125100+104.60621
库存:226
