YG0035AA
YG0035AA
    QUECTEL(移远)
    1.561GHz,1.575GHz BeiDou,Galileo,GLONASS,GNSS,GPS 圆顶 RF 天线 1.5dBi,1.5dBi SMA 公头 磁性
YG0035AA 数据手册
1 Contents 01 Quectel Antenna Services 01 Quectel Advantages 01 Instruments 02 5G Antennas 04 Cellular (4G/3G/2G) Antennas 08 GNSS Antennas 14 Wi-Fi & Bluetooth Antennas 15 Combo Antennas 17 ISM Antennas 17 Cable Assemblies Quectel Antenna Services Consulting & Evaluation Design ■ Feasibility & Architecture Study ■ Antenna Placement ■ Risk Identification ■ Antenna Layout Design ■ Initial Proof of Concept ■ RF Specification Design ■ Antenna Component Selection ■ Antenna System Design & Optimization ■ Gerber File Review Testing & Certification Manufacturing ■ Antenna OTA Testing ■ Antenna Samples ■ Interference Mitigation ■ Tooling & Molding ■ Support for CE/FCC/PTCRB Radio Approval ■ Assembly and Production Testing ■ Pre-certification OTA Testing for 2G/3G/4G/5G ■ Delivery Quectel Advantages Solutions for the Entire Wireless RF Front End Antenna Complete RF Antenna Testing Services Global One Stop Engineering Support Vertical Integration of Antenna Resources Module Engineering Support Approved for Use with Quectel Modules Instruments Keysight CATR2305G Rhode & Schwarz WPTC-XS RayZone2800 ETS-AMS-8923-150 1 Quectel Antennas 5G Antennas Product YE0001BA YE0003AA YE0007AA YE0025AA Frequency Bands (MHz) 600–6000 699–5000 600–6000 698–960,1710–5000 Technology 5G 5G 5G 5G Cable Length (mm) n/a n/a n/a n/a Connector Type SMA Male (center pin) SMA Male (center pin) SMA Male (center pin) SMA Male (center pin) Mounting Type Terminal Terminal Terminal Terminal Dimensions (mm) 221 × 26.95 × 13.5 190 × Φ 16 152.4 × 21.79 × 14.49 199 × 22 Matched Quectel Modules 5G/4G/3G/2G/LPWA 5G Antennas Product YE0027AA YE0028AA YE0037AA YXH001AA YBY00A0KA Frequency Bands (MHz) 699–5000 700–2700, 3300–5000 700–5000 700–960, 1710–2690, 3300–5000 700–960, 1710–2690, 3300–5000 Technology 5G 5G 5G 5G 5G Cable Length (mm) 3000 1500 1000 1000 n/a Connector Type SMA Male (center pin) SMA Male (center pin) SMA Male (center pin) SMA Male (center pin) N-J (Male pin with internal thread) Mounting Type Magnetic Magnetic Magnetic Magnetic Terminal Dimensions (mm) 221 × Φ 61 234 × Φ 60 88 × Φ 30 285 × 45 Φ 20 × 300 Matched Quectel Modules 5G/4G/3G/2G/LPWA The parameters shall be subject to the Specification. 2 Quectel Antennas 5G Antennas Product YF0002AA YF0002BA YF0002CA YF0002DA Frequency Bands (MHz) 700-960, 1710-2700, 3300-5000 1710-2700, 3300-5000 1710-2700, 3300-5000 700-960, 1710-2700, 3300-5000 Technology 5G 5G 5G 5G Cable Length (mm) n/a n/a n/a n/a Connector Type Spring contact Spring contact Spring contact Spring contact Mounting Type Screw Screw Screw Screw Dimensions (mm) 60.1 × 12.25 × 10.1 41.25 × 10.1 × 10.1 37.25 × 9.6 × 10.1 50.25 × 20.1 × 10.1 Matched Quectel Modules 5G/4G/3G/2G/LPWA 5G Antennas Product YF0017AA YF0017BA YF0020AA YC0018AA YC0018AAEVB Frequency Bands (MHz) 1500–6000 1100–6000 600–6000 617-6000 617-6000 Technology 5G 5G 5G 5G 5G Cable Length (mm) 193 ±3 193 ±3 184 ±3 n/a n/a Connector Type IPEX Ⅳ IPEX Ⅳ IPEX Ⅳ n/a n/a Mounting Type Adhesive Adhesive Adhesive SMD n/a Dimensions (mm) 49 × 13 × 0.13 49 × 13 × 0.13 90.15 × 15.2 × 0.13 42 × 7 × 3 140 × 40.4 Matched Quectel Modules 5G/4G/3G/2G/LPWA The parameters shall be subject to the Specification. 3 Quectel Antennas 5G Antennas Product YP0009AA YP0009BA YP0009CA Frequency Bands (MHz) 1500–6000 1100–6000 600–6000 Technology 5G 5G 5G Cable Length (mm) 193 ±3 193 ±3 188 ±3 Connector Type IPEX Ⅳ IPEX Ⅳ IPEX Ⅳ Mounting Type Adhesive Adhesive Adhesive Dimensions (mm) 49 × 13 × 0.85 49 × 13 × 0.85 78.5 × 14.2 × 0.85 Matched Quectel Modules 5G/4G/3G/2G/LPWA Cellular (4G/3G/2G) Antennas Product YC0001AA YC0002AA YC0003AA YC0003AAEVB YC0017BA YC0017BAEVB Frequency Bands (MHz) 698–960, 1710–2690 698–960, 1710–2690 698-2700 698-2700 698-3800 698-3800 Technology LTE (4G) LTE (4G) LTE (4G) LTE (4G) LTE (4G) LTE (4G) Cable Length (mm) n/a n/a n/a n/a n/a n/a Connector Type n/a n/a n/a n/a n/a n/a Mounting Type SMD SMD SMD n/a SMD n/a Dimensions (mm) 35.0 × 8.5 × 3.0 42 × 10 × 3 40 × 7 × 3 120 × 43 26 × 8 × 3 140 × 36 Matched Quectel Modules 4G/3G/2G/LPWA The parameters shall be subject to the Specification. 4 Quectel Antennas Cellular (4G/3G/2G) Antennas Product YF0022AA YF0007BA YPCA004AA Frequency Bands (MHz) 700–2690 600–960, 1427.9–1495.9, 1710–2170, 2300–2700 700–2690 Technology LTE (4G) LTE (4G) LTE (4G) Cable Length (mm) 75 ±3 75 ±3 100 ±3 Connector Type RF1 RF1 IPEX Ⅰ Mounting Type Adhesive Adhesive Adhesive Dimensions (mm) 40 × 15 × 1.6 50 × 25 × 0.85 40 ×10 × 1 Matched Quectel Modules 4G/3G/2G/LPWA Cellular (4G/3G/2G) Antennas Product YFCA002AA YF0006DA YF0028AA Frequency Bands (MHz) 700–2690 690–960, 1710–2170, 2300–2690 698-3000 Technology LTE (4G) LTE (4G) LTE (4G) Cable Length (mm) 75 ±3 75±3 150 ±2 Connector Type RF1 IPEX Ⅰ IPEX Ⅰ Mounting Type Adhesive Adhesive Adhesive Dimensions (mm) 30 × 20 × 0.13 50 × 25 × 0.13 96 × 21 × 0.2 Matched Quectel Modules 4G/3G/2G/LPWA The parameters shall be subject to the Specification. 5 Quectel Antennas Cellular (4G/3G/2G) Antennas Product YECT002AA YECT003AA YE0009AA YPR00A0AA YCN001AA Frequency Bands (MHz) 700–960,1710–2690 698-960, 1710-2700 824–2700 700–2700 700–2700 Technology LTE (4G) LTE (4G) LTE (4G) LTE (4G) LTE (4G) Cable Length (mm) n/a n/a n/a n/a n/a Connector Type SMA Male (center pin) SMA Male (center pin) SMA Male (center pin) SMA Male (center pin) SMA Male (center pin) Mounting Type Terminal Terminal Terminal Terminal Terminal Dimensions (mm) 196.2 × 16 × 13 113× Φ 10 190 × 16 194.3 ×15.95 144 × Φ 13 Matched Quectel Modules 4G/3G/2G/LPWA Cellular (4G/3G/2G) Antennas Product YE0006AA YE0010AA YB0010AA YB0016AA Frequency Bands (MHz) 700–2700 698–2700 698–960, 1710–2690 698–960, 1710–2700 Technology LTE (4G) LTE (4G) LTE (4G) LTE (4G) Cable Length (mm) 1500 1000 ±30 2000 ±30 3000 ±50 Connector Type SMA Male (center pin) SMA Male (center pin) SMA Male SMA Male (center pin) Mounting Type Magnetic Adhesive Magnetic Screw Dimensions (mm) 318 × Φ 30 152 × 18 × 5.9 Φ 81.5 × 16 54 × 91 Matched Quectel Modules 4G/3G/2G/LPWA The parameters shall be subject to the Specification. 6 Quectel Antennas Cellular (4G/3G/2G) Antennas Product YE0012AA YE0021AA YE0029AA Frequency Bands (MHz) 824–960, 1710–2690 690–960, 1710–2690 700–2700 Technology LTE (4G) LTE (4G) LTE (4G) Cable Length (mm) 250 ±10 1500 ±30 3000 ±50 Connector Type SMA Male (center pin) SMA Male (center pin) SMA Male (center pin) Mounting Type Adhesive Magnetic Magnetic Dimensions (mm) 116.5 × 21.7 × 5.6 112 × 29.8 88 × Φ 30 Matched Quectel Modules 4G/3G/2G/LPWA Cellular (4G/3G/2G) Antennas Product YDX001AA YE0002AA YE0013AA YGL001AA Frequency Bands (MHz) 824–2690 699–2700 700–2700 700–960,1710–2690 Technology LTE (4G) LTE (4G) LTE (4G) LTE (4G) Cable Length (mm) n/a n/a n/a n/a Connector Type SMA Male (center pin) RP-SMA Male (center receptacle) SMA Male (center pin) SMA Male (center pin) Mounting Type Terminal Terminal Terminal Terminal Dimensions (mm) 208 × Φ 12 174.6 × 19.2 115.4 × 17.5 × Φ 10.2 196.2 × 16 × 13 Matched Quectel Modules 4G/3G/2G/LPWA The parameters shall be subject to the Specification. 7 Quectel Antennas Cellular (4G/3G/2G) Antennas Product YE0008AA YE0011AA YKL001CA Frequency Bands (MHz) 824–960, 1710–2170 , 2500–2700 824–960, 1710–2170, 2500–2700 NB: 800–1000, 1700–1900 Technology LTE (4G) LTE (4G) 2G/3G/NB-IoT Cable Length (mm) n/a n/a 310 ±10 Connector Type SMA Male (center pin) SMA Male (center pin) SMA Male (center pin) Mounting Type Terminal Terminal Screw Dimensions (mm) 52 × Φ 10 50 × Φ 10 50 × 48 Matched Quectel Modules LPWA/3G/2G module series GNSS Antennas Product YC0013AA YC0013AAEVB YC0008AA YC0008AAEVB Frequency Bands (MHz) 1559-1606 1559-1606 1173, 1575 1173, 1575 Technology GNSS GNSS GNSS L1 & L5 (passive) GNSS L1 & L5 (passive) Cable Length (mm) n/a n/a n/a n/a Connector Type n/a n/a n/a n/a Mounting Type SMD n/a SMD n/a Dimensions (mm) 3.2 × 1.6 × 0.6 90 × 50 30 × 5 × 5 80 × 36 Matched Quectel Modules GNSS L1 module series The parameters shall be subject to the Specification. 8 GNSS L1/L5 module series Quectel Antennas GNSS Antennas Product YCGA001AA YCGA002AA YG0038AA Frequency Bands (MHz) 1559-1606 1559-1606 1559-1606 Technology GNSS L1 GNSS L1 GNSS L1 Cable Length (mm) n/a n/a n/a Connector Type n/a n/a n/a Mounting Type Pin Mounting Pin Mounting Pin Mounting Dimensions (mm) 10 × 10 × 4 12 × 12 × 4 13 × 13 × 4 Matched Quectel Modules GNSS L1 module series GNSS Antennas Product YG0043AA YG0046AA YG0005AA YG0062AA YG0048AA Frequency Bands (MHz) 1559-1606 1559-1606 1559-1606 1559-1606 1176, 1575 Technology GNSS L1 GNSS L1 GNSS L1 GNSS L1 GNSS L1 & L5 Cable Length (mm) n/a n/a n/a n/a n/a Connector Type n/a n/a n/a n/a n/a Mounting Type Pin Mounting Pin Mounting Pin Mounting Pin Mounting Pin mounting Dimensions (mm) 15 × 15 × 4 18 × 18 × 2 18 × 18 × 4 25 × 25 × 4 18 × 18 × 4 & 25 × 25 × 4 Matched Quectel Modules GNSS L1 module series GNSS L1/L5 module series The parameters shall be subject to the Specification. 9 Quectel Antennas GNSS Antennas Product YCGO004AA YCGO005AA YCGO006AA YCGO007AA YG0034AA YG0021AA Frequency Bands (MHz) 1559-1606 1559-1606 1559-1606 1559-1606 1559–1606 1560–1605 Technology GNSS L1 (passive) GNSS L1 (passive) GNSS L1 (passive) GNSS L1 (passive) GNSS L1 (active) GNSS L1 & B1 & G1 (active) Cable Length (mm) 50±2 50±2 50±2 50±2 35±2 42 ±3 Connector Type IPEX Ⅰ IPEX Ⅰ IPEX Ⅰ IPEX Ⅰ IPEX Ⅰ IPEX Ⅰ Mounting Type Cable Mounting Cable Mounting Cable Mounting Cable Mounting Cable Mounting Cable Mounting Dimensions (mm) 10 × 10 × 6.5 15 × 15 × 6.5 18 × 18 × 6.5 25 × 25 × 6.5 13 ×13 × 6.8 18.4 × 18.4 × 8.86 Matched Quectel Modules GNSS L1 module series GNSS Antennas Product YG0032AA YG0015AA YCGO008AA YCGO009AA YCGO010AA YCGO011AA Frequency Bands (MHz) Beidou: 1561 ±5 ; GPS: 1575 ±5 1559–1606 1559-1606 1559-1606 1559-1606 1559-1606 Technology GNSS L1 & B1 & G1 (active) GNSS L1 (active) GNSS L1 (active) GNSS L1 (active) GNSS L1 (active) GNSS L1 (active) Cable Length (mm) 55 55 ±3 50±3 50±2 50±3 50±3 Connector Type IPEX Ⅰ IPEX Ⅰ IPEX Ⅰ IPEX Ⅰ IPEX Ⅰ IPEX Ⅰ Mounting Type Cable Mounting Cable Mounting Cable Mounting Cable Mounting Cable Mounting Cable Mounting Dimensions (mm) 18 × 18 × 6.6 25 × 25 × 8.25 10 × 10 × 6.5 15 × 15 × 6.5 18 × 18 × 6.5 25 × 25 × 6.5 Matched Quectel Modules GNSS L1 module series The parameters shall be subject to the Specification. 10 Quectel Antennas GNSS Antennas Product YCGS004AA YCGS005AA YCGS006AA Frequency Bands (MHz) 1560–1606 1560–1606 1560–1606 Technology GNSS L1 & G1 GNSS L1 & G1 GNSS L1 & G1 Cable Length (mm) n/a n/a n/a Connector Type n/a n/a n/a Mounting Type SMD SMD SMD Dimensions (mm) 9 ×9 ×4 18 × 18 × 4 25 × 25 × 4 Matched Quectel Modules GNSS L1 module series GNSS Antennas Product YAT001AA YAT001BA YBS00A1AA Frequency Bands (MHz) 1176, 1575 1176, 1575 1176, 1575 Technology GNSS L1 & L5 (active) GNSS L1 & L5 (active) GNSS L1 & L5 (active) Cable Length (mm) n/a n/a n/a Connector Type n/a n/a n/a Mounting Type Cable Mounting Cable Mounting Cable Mounting Dimensions (mm) 25 × 25 × 4 & 18 × 18 × 4 25 × 25 × 2 & 18 × 18 × 2 40 × 40 × 4 & 45 × 45 × 6 Matched Quectel Modules GNSS L1/L5 module series The parameters shall be subject to the Specification. 11 Quectel Antennas GNSS Antennas Product YAT001CA YG0030AA YCGO014AA Frequency Bands (MHz) 1176, 1575 1176, 1575 L5: 1166–1186 L1: 1559–1606 Technology GNSS L1 & L5 (active) GNSS L1 & L5 (passive) GNSS L1 & L5 (passive) Cable Length (mm) 40 ±2 100 ±2 142 Connector Type IPEX Ⅰ IPEX Ⅰ IPEX Ⅰ Mounting Type Cable Mounting Cable Mounting Cable Mounting Dimensions (mm) 25 × 25 × 2 & 18 × 18 × 4 52 × 52 × 9.9 50 × 50 × 19.0 Matched Quectel Modules GNSS L1/L5 module series GNSS Antennas Product YFGA001AA YFGA002AA YFGA003AA YFGA004AA Frequency Bands (MHz) 1160–1270, 1560–1605 1559–1609 1559–1609 1160–1270, 1560–1605 Technology GNSS L1 & 2 & L5 & L6 GNSS L1 GNSS L1 GNSS L1 & 2 & L5 & L6 Cable Length (mm) 100 100 100 100 Connector Type IPEX Ⅰ IPEX Ⅰ IPEX Ⅰ IPEX Ⅰ Mounting Type Adhesive Adhesive Adhesive Adhesive Dimensions (mm) 74.56 × 24.5 × 0.25 61.15 × 11.24 39.45 x 13.25 43 × 24 × 0.12 Matched Quectel Modules GNSS L1/L5 module series GNSS L1 module series The parameters shall be subject to the Specification. 12 GNSS L1/L5 modules Quectel Antennas GNSS Antennas Product YG0035AA YLY001CA YB0017AA YG0028AA Frequency Bands (MHz) 1561, 1575 1568 ±10 GPS L1/L5, BD B1/B2, GLONASS L1 1561–1602, 1166–1186 Technology GNSS L1 & B1 & G1 (active) GNSS L1 & B1 & G1 (active) GNSS L1 & L5 (active) GNSS L1 & L5 (active) Cable Length (mm) 3000 ±20 2000 L = 3000 3000 Connector Type SMA Male (center pin) SMA Male (center pin) SMA Male (center pin) SMA Male (center pin) Mounting Type Magnetic Magnetic Magnetic Magnetic Dimensions (mm) 50.3 × 38.4 × 17.1 45.5 × 38 × 13.5 61.5 × 56.5 × 23 Φ 54 × 38 Matched Quectel Modules GNSS L1 module series GNSS L1/L5 module series GNSS Antennas Product YG0065AA YEGT001AA YEGT002AA YG0063AA Frequency Bands (MHz) 1575–1602 1559-1606 1559–1606 GPS L1/L2/L5; BDS B1/B2/B3; GLONASS L1/L2; Galileo E1/E5a/E5b/E6; L-band Technology GNSS L1 (active) GNSS L1 GNSS L1 All GNSS bands + L-band Corrections Cable Length (mm) 3000 n/a n/a n/a Connector Type FAKRA Female (Code C) SMA Male (center pin) SMA Male (center pin) TNC Female Mounting Type Magnetic Terminal Terminal Screw Dimensions (mm) 34.5 × 37.5 × 12.5 50 × Ø10 52 × Ø10 Φ 165 × 68 Matched Quectel Modules GNSS L1 modules All GNSS L1 modules All GNSS L1/L2/L5 modules The parameters shall be subject to the Specification. 13 Quectel Antennas Wi-Fi & Bluetooth Antennas Product YC0009AA YC0010AA YEWM001AA Frequency Bands (MHz) 2400–2500 2400–2500 2400–2500 Technology Wi-Fi (Bluetooth) Wi-Fi (Bluetooth) Wi-Fi (Bluetooth) Cable Length (mm) n/a n/a 1500 Connector Type n/a n/a SMA Male (center pin) Mounting Type SMD SMD Magnetic Dimensions (mm) 3.2 × 1.6 × 0.5 5.2 × 2.0 × 1.2 Φ 30 ×77.4 Matched Quectel Modules FC30R Wi-Fi & Bluetooth Antennas Product YF0011AA YF0026AA YF0027AA YF0029AA YF0023AA Frequency Bands (MHz) 2400–2500, 5150–5850 2400–2500, 4900–5850, 5925-7125 2400–2500, 4900–5850, 5925-7125 2410–2490 , 4920–5925 2400–2500, 5150–5850, 5925-7125 Technology Wi-Fi (Bluetooth) Wi-Fi (Bluetooth) Wi-Fi (Bluetooth) Wi-Fi (Bluetooth) Wi-Fi (Bluetooth) Wi-Fi (Bluetooth) Cable Length (mm) 44 ±13 100 ±2 100 ±2 100 ±2 100±2 100±2 Connector Type IPEX Ⅰ (U.FL Generation Ⅰ) IPEX Ⅰ (U.FL Generation Ⅰ) IPEX Ⅰ (U.FL Generation Ⅰ) IPEX Ⅰ (U.FL Generation Ⅰ) RF I Generation RF I Generation Mounting Type Adhesive Adhesive Adhesive Adhesive Adhesive Adhesive Dimensions (mm) 38.9 × 9 × 0.12 28.9 × 11 × 0.2 42 × 7 × 0.2 30 × 30 × 0.25 22.90 × 11.70 37.80 × 7.50 Matched Quectel Modules All Wi-Fi/BT modules (Except Wi-Fi 6E) All Wi-Fi/BT modules All Wi-Fi/BT modules (Except Wi-Fi 6E) All Wi-Fi/BT modules The parameters shall be subject to the Specification. 14 YF0023CA 2400–2500, 5150–5850, 5925-7125 Quectel Antennas Wi-Fi & Bluetooth Antennas Product YE0031AA YE0032AA YE0038AA YEWT004AA YEWN001AA Frequency Bands (MHz) 2.4–2.5 GHz, 5.15–5.85 GHz 2.4–2.5 GHz, 5.15–5.85 GHz 2400–2500, 5150–5850 2400–2500, 5150–7150 2400–2500, 5150–5850 Technology Wi-Fi (Bluetooth) Wi-Fi (Bluetooth) Wi-Fi (Bluetooth) Wi-Fi 6E (Bluetooth) Wi-Fi (Bluetooth) Cable Length (mm) n/a n/a n/a n/a n/a Connector Type SMA Male (center pin) SMA Male (center pin) SMA Male (center pin) SMA Male (center pin) RP-SMA Male (Center Receptacle) Mounting Type Terminal Terminal Terminal Terminal Terminal Dimensions (mm) 52 ±2 50 ±2 195 × 13 109 × Φ 10 200 × 13 Matched Quectel Modules All Wi-Fi/BT modules (Except Wi-Fi 6E) All Wi-Fi/BT modules All Wi-Fi/BT modules (Except Wi-Fi 6E) Combo Antennas Product YB0007AA YB0008AA YB0009AA YB0014AA Frequency Bands (MHz) 700–960, 1710–2690 , 3300–5000 4G MAIN: 698–960, 1710–2690; GNSS: 1575.42 ±5, 1561.098 ±5; 4G DIV: 1710–2690 4G: 824–960, 1710–2690; GPS, BD: 1575.42 ±10, 1561 ±10 LTE Main & Div: 698–960, 1700–2700; GNSS: 1561–1571; 1602–1606 Technology 5G Main LTE & DIV LTE & GNSS LTE & GNSS Main LTE & DIV LTE & GNSS Cable Length (mm) 500 300 310 3000 Connector Type SMA Male (center pin) SMA Male (center pin) SMA Male (center pin) SMA Male (center pin) Mounting Type Screw Adhesive Screw Screw Dimensions (mm) Φ 120 × 43 Φ 84 × 17.5 33 × 48 81 × 27.5 Matched Quectel Modules All 5G modules (RM50xQ Series, RG50xQ Series) & All 4G/3G/2G modules & GNSS L1 modules All 4G/3G/2G modules & GNSS L1 modules The parameters shall be subject to the Specification. 15 Quectel Antennas Combo Antennas Product YB0015AA YKL001AA YB0032AA YB0033AA YB0022AA Frequency Bands (MHz) LTE: 698–960, 1700–2700; Wi-Fi, Bluetooth: 2400– 2500; GNSS: 1561 ±5, 1575 ±5 Bluetooth: 2400–2500; 4G: 824–960; 1710–2690; GPS, BD: 1575.42 ±10, 1561 ±10 700–960, 1700–2700 LTE Main & Div: 700–960, 1700–2700 ; GNSS: 1559– 1610 (active) LTE Main & Div: 700–2700; Wi-Fi: 2400–5850 ; GNSS: 1561/1575.42/1602 Technology LTE/GPS & BD/Wi-Fi LTE/GPS & BD/Wi-Fi Main LTE & DIV LTE Main LTE & DIV LTE & GNSS Main LTE & DIV LTE & GNSS & Wi-Fi1 & Wi-Fi2 Cable Length (mm) 300 310 2000 2000 1000 Connector Type SMA Male (center pin) SMA Male (center pin) SMA Male (Center Pin) SMA Male (Center Pin) FME Female Connector Mounting Type Screw Screw Screw Screw Screw Dimensions (mm) 54 × 91 33 × 48 Φ 120 × 43 Φ 120 × 43 Φ 120 × 43 Matched Quectel Modules 4G/3G/2G modules & GNSS L1 modules & Wi-Fi modules All 4G/3G/2G modules All 4G/3G/2G modules & GNSS L1 modules 4G/3G/2G modules & GNSS L1 modules & Wi-Fi, Bluetooth modules Combo Antennas Product YB0031AA YEMA003AA YEMA004AA YWL00A0AA YB0026AA YEWN004AA Frequency Bands (MHz) LTE: 698–960; 1710–2690; GNSS: 1575.42 ±5, 1561.098 ±5 LTE: 700–2700 1561/1575.42/1602 4G: 698–960 , 1710–2690 Wi-Fi & Bluetooth: 2400–2500 698–960, 1710–2690 LTE: 700–2700 ; Wi-Fi: 2400–5850; GNSS: 1561/1575.42/1602 2400–2500, 5150–5850 Technology LTE & GNSS LTE & GNSS LTE & Wi-Fi Main LTE & DIV LTE LTE & GNSS & Wi-Fi1 & Wi-Fi2 Wi-Fi MIMO Cable Length (mm) 300 3000 900 1500 1000 300 Connector Type SMA Male (center pin) 4G: FAKRA D GNSS: FAKRA C SMA Male (Center Pin) SMA Male (Center Pin) GNSS: FAKRA_C, LTE: FAKRA_D, Wi-Fi 1: FAKRA_ SMA Male (Center Pin) I, Wi-Fi 2: FAKRA_I Mounting Type Adhesive Adhesive Screw Screw Screw Screw Dimensions (mm) Φ 84 ×17.5 Φ 84 × 17.5 Φ 81 ×14.5 Φ 81 × 27.5 Φ 120 ×43 Φ 46 ×15 Matched Quectel Modules All 4G/3G/2G modules & GNSS L1 modules All 4G/3G/2G modules & Wi-Fi modules All 4G/3G/2G modules All 4G/3G/2G modules & GNSS L1 modules & Wi-Fi, Bluetooth modules Wi-Fi modules The parameters shall be subject to the Specification. 16 Quectel Antennas ISM Antennas Product YE0019AA YE0039BA YEIM001AA Frequency Bands (MHz) 450–470 430-470, 790-960 465–475 Technology ISM ISM ISM Cable Length (mm) / 75 2000 Connector Type SMA Male (center pin) SMA Male (center pin) SMA Male (center pin) Mounting Type Terminal Adhesive Magnetic Dimensions (mm) 109 × 10 117 × 21.81 × 5.47 Φ 30 × 131 Cable Assemblies Product YM0003AA YM0015AA YM0003CA YM0003AB YM0013AA Frequency Bands (MHz) 0–6000 0–6000 0–6000 0–6000 0–6000 Technology Cable Cable Cable Cable Cable Cable Length (mm) 100 150 200 200 300 Connector Type SMA-female to IPEX Ⅰ SMA-female to IPEX Ⅰ SMA-female to IPEX Ⅰ RP-SMA-female to IPEX Ⅰ SMA-female to IPEX Ⅰ Mounting Type Screw Screw Screw Screw Screw Dimensions (mm) 100 150 200 200 300 Matched Quectel Modules All modules (5G excluded) Product YM0004AA YM0005AA YSAN001AA YBY00A0HA YBY00A0JA YBY00A0IA Frequency Bands (MHz) 0–6000 0–6000 0–6000 0–6000 0–6000 - Technology Cable Cable Cable Cable Cable Bracket Cable Length (mm) 100 150 300 200 250 - Connector Type SMA-female to IPEX Ⅳ SMA-female to RF Ⅳ SMA-female to RF Ⅳ N-K-female to IPEX Ⅰ N-female to IPEX Ⅰ - Mounting Type Screw Screw Screw Screw Screw - Dimensions (mm) 100 150 300 200 250 - Matched Quectel Modules All 5G modules (RM50xQ Series, RG50xQ Series) All modules (5G excluded) All modules The parameters shall be subject to the Specification. 17 V1.7.4 2022.04
YG0035AA 价格&库存
很抱歉,暂时无法提供与“YG0035AA”相匹配的价格&库存,您可以联系我们找货
YG0035AA
  • 1+74.326361+9.65462
  • 10+57.6111910+7.48340
  • 25+53.4249925+6.93964
  • 100+48.82147100+6.34166
库存:197
